So about 2 months ago i purchased the gorgeous B&O Form 2 headphones from Greece. The sound was WOW. The Best! Bass and everything worked great. From my iPhone, iPod and Mac! Yesterday i was listening to music from my Mac for about an hour and then i decided to leave my desk and listen to music from my iPhone. The sound was still great but when there was bass i heard a continuous zzzzz from the left side. Put them on my Mac. SAME. iPod. Same. WHY?????
I suggest a loose connection , probably in the jack plug. Take them to a B&O dealer - he will probably simply replace them.
Peter
Thank you
Is the buzzing sound only happening when the bass notes are played?
Mainly yes
madsilencerr: Mainly yes
Ok I get the same problem all the time, what has happened is a hair has fallen between the small gaps on the earpiece so it rattles around every time the driver vibrates therefore making the buzzing noise. all you need to do is see if you can see any hairs sticking out of the gaps, if not, remove the foam pad and see if you can find it. Or if you have fairly long hair that when you put them on covers part of the headphones then you need to tuck your hair back so no hairs are covering or going into the small gaps at the back of the earpiece. Bit of a design fault in my opinion but will just have to live with it.
