The drawer motor on my Beocord 5000 tends to run for several seconds before stopping, after the drawer has opened or shut....And its not quiet either. Its my only issue but I dont want the motor to burn out or any thing else to happen from prolonged use in this condition. The motor runs louder than I remember it. Any ideas?
Thanks all.
Mark
Welcome to Beoworld !
Perfectly normal less the noise, if excessive.If you can hear the motor run after the drawer has fully closed or opened, the belt is slipping andmust be replaced (I can supply exact reproduction belts).
I got my belt from Martin, works, as parts from Martin always do.
And check here to change the belt
That must be it. I would love a new belt. If you sell a belt kit for the Beocord 5000 that includes all belts that would be nice as well.
Thanks Martin
Sure.Belts are available as a kit and mounting instructions with photos and text are too.
You have an email.
Drawer belt was the answer. Works like new now. Thanks!
Great to know, same problem here. Thanks!
Jacques
Hi
please could I purchase a drawer belt off you?
thank you
Welcome to Beoworld!You have email.
