V1 Problems!
This post has 47 Replies | 3 Followers
shinobi52
Posts 87
After a few hours on the same source, the Tv says that she will shut down if you don't push the remote. This is the eco mode. My wife was thinking that the Tv had a problem untill we see the popup on the screen...
Hero71
Posts 79
Hero71 replied on Tue, Nov 6 2012 8:19 PM
Mdjolly1973:
HiIve had my V1 for a few months now and over the last week its been randomly switching itself off....i switch it back on,works fine for a length of time then switches off again! Software issue or shall i ask the dealer to replace tv?
This is the eco-setting. By default it is set to turn of the V1 autmatically after 4 hours of uniterupted use.
The abrupt shutdown I'm having on my V1 occurs while using it, it shuts down all of a sudden (no closing curtains, everything is turned off instantly). There is a disruption in all speakers when it happens. The V1 automatically restarts, however, external speakers remain switched off and the picture of the V1 remains black after the restart. When selecting a source, the image of the selected source appears instantly and any external speakers are turned on instantly.
Mdjolly1973
Posts 51
No mine switches off after five minutes,twenty minutes and other random times!
Hero71
Posts 79
Hero71 replied on Wed, Nov 7 2012 5:41 AM
Mdjolly1973:
That is abnormal, contact your dealer! I would think that if certain issues were software related, they would appear on a more larger scale.
stijndc
Mechelen - Belgium
Posts 35
stijndc replied on Fri, Jan 16 2015 1:46 PM
@Hero71 What was the outcome of the green aurora problems which you experienced with your Beoplay V1? I have acually the same issues (with different sources; apple TV and my set-up box).
Thanks in advance!
stijndc
Mechelen - Belgium
Posts 35
stijndc replied on Tue, Mar 3 2015 9:58 PM
Anyone? Unsure
Griebel
Posts 416
Griebel replied on Tue, Mar 3 2015 10:23 PM
Had a similar problem on a 7-55, but the screen displayed red instead of green in your case. A graphic card was dead. Once replaced everything came back to normal.
Michael
Sweden
Posts 2,578
Michael replied on Tue, Mar 3 2015 11:20 PM
My V1 has always blinked green for a second after being turned on, it blinks green after a few seconds or after a few minutes. Not always the same but always the green flash. My warranty ends soon but it is hard to send it in for that I think. Anyone else who has a V1 that does the same?
Page 2 of 2 (48 items) < Previous 1 2 | RSS
