BS3 (valid for all BS3 based TVs) Latest software : 10.05a
(no changelog)
SW 10.02 (build 814) - 11/2010 - Changelog : - Bugfixes - Possibility to deactivate center speaker - Fans start up delayed by 20s
SW 9.01 (build 714) - 12/10/2010 - Changelog : - Sleep Timer(how it could take B&O 1 million years to implement that i dont know?) :) - "Game mode" under picture settings, don't know what it does. - New DVB-HD logo instead of that hideous clock screen - Fix for the dark screen issue? - Auto standby
SW 8.12a (Build 632) 26/04/2010 - Changelog :
Build 632 - Master Link delay and feature activation. New features 1. Sound delay for sound on Master Link, elimination of echo when same source is used in main and link room. See also Master Link delay 2. Possibility of naming individual sources, e.g. the source name “PC” can be changed to “MyMac”. The option is present on all sources connected to an AV connection, but not on built-in sources. 3. Feature activation incl. support for HDMI video distribution. · Activation of this feature requires purchase of an activation key specific to the television set. · Distribution of HD signals via HDMI/CAT7 cables to link rooms using an HDMI Matrix (third-party equipment). · Can ONLY be controlled by Beo5. Special template is being developed. 4. Setup option for Beo4 Setting, only “no Navigation button” can be selected, feature is for future use.
SW 8.02 (Build 551) - 03/2010
SW 7.05 (Build 551) - 02/11/2009 :
1. No menu, no overlay menu, no curtains (Build 548).2. Menus and OSD disappeared (Build 548).3. BeoSystem 3 freezes when receiving DTV+CINEMA_OFF from standby (Build 548).4. TV does not go into standby, and standby diode is blinking (slow flash) (Build 548).5. Intermittently the television switches off (Build 548).6. ACM crashes when source is YPbPr in High-Definition (was solved in Build 533) (Build 548).7. No volume bar after using EPG in DVB-HD (Build 548).8. Panel info says 50 Hz and not 100 Hz (Build 548).9. No link control of DTV source (STB), if main room television is in standby (was solved in Build 533).10. Lip-sync on Blu-ray does not match.11. Timer on DTV-RADIO. Turn on to last shown TV (DTV) channel when link TV is connected.12. Non B&O screen: Screen switches on when switching off from audio mode.13. Not correct channel is showed when Play timer from another favourites list is programmed.14. Difference in sound level between DVB picture and DVB Full-text.15. Different issues with opening and closing curtains (half open-half closed).16. Mixed sound from Radio and DVD in link room.17. Stand does not always turn to stored positions.
Note : This update adds a bug on BV7 which makes the fan too much audible... Next update : 7.11, soon!BV10 + BV8 40 SW (valid for BV8 40, BV10 40, BV10 46, BV7 32mkV, BV6 26 mkII) latest Build : 224 - 2/2012 (no changelog)
Build 210 - 09/2011 (no changelog)Build 165 - 02/2011 (no changelog)Build 155 - 01/2011 (no changelog)Build 153 - 10/2010 - Changelog :
- Low picture/menu quality on DVB-HD - A loud ticking noise is heard when stepping up/down on Humax 5050/5000 set-top box - The previous factory Build 126 had issues resolved by this update - After a period of time there is no set-top box IR-control - Incorrect translation from DVB-HD
Build 127 - 5/07/2010 -Changelog : - Fixes the DVB-HD blocking problem of build 126 (if Radio and then standby was selected)
Build 126 Release date 1-07-2010 (added a DVB-HD blocking problem if Radio and then standby was selected, updated by build 127) - Darker default picture on BV10 in order to lower visible clouding - Hideous timer logo removed from DVH-HD startup, replaced by a small B&O logo - Naming of sources can be personnalised by user (BV7-style)
Version Build 109e Release date 26-04-2010 (no changelog)
Version Build 109b. Release date 15-03-2010 (no changelog) Version Build 86b. Release date 28-10-2009, new Features :
1. On-screen menus changed (black menus)2. Sleep timer function.3. You can add additional HDMI sources connecting an HDMI Expander to the HDMI B socket.4. Speaker mode 1 can be selected as standard setup in Video mode even if front and rear speakers are in the setup.5. If used with RS4 software or higher on DVB-HD, then MHEG is possible in UK.
DVB HD (MKI/MKII) module (found on BV7, BV8 and BV10) This software update can be done by the user : download it here : http://www.bang-olufsen.com/dvb-hd/software-downloads
Latest version : 0.1.8.9.0 - 11/2011 - Changelog : - Semitransparent EPG + bug corrections
0.1.7.1.0 - 7/20110.1.6.5.0 - 3/20110.1.4.7.0 - 11/06/20100.1.4.5.0 - 12/05/2010
BV7-32/TYPE 9312/MKII : Latest Software : 6.33
BeoCenter 6-23MKII/26 (Type 9219-9226, 9280-9287)Latest Software 10.10A
Beovision 6-22 : latest software : 5.23a
BS5 SW 6.05.01.3357
Possibility to rip at MP3/320kbps with CD Ripping device instead of WMA Lossless (for compatibility with iDevices)
SW 6.05 - 12/2011
2-way mode for Beo6Ripping device supportSW 6.01 - 2/06/2010
MOTS features · Exclude from MOTS · Exclude from previous album · Disable MOTS · MOTS status + progress bar · MOTS logo · MOTS button on Beo4 (1710)
System functionality · BeoSound 5 placement in link rooms · BeoSound 5 in option 1.1 and 2.2 · BeoVision 8-40, 10-40 and 10-46 compatibility · Master Link Gateway compatibility · Support for older televisions / IR compatibility · Play Timer (on/off) · More than one BeoSound 5/BeoMaster 5 in a setup
Other refinements · OS updated to version 6.01 · Performance at start-up improved · Password in user service menu · Show share & user name in NETWORK INFO · New setting for N.Radio buffer length · New setting for adjustable start time in N.Music · ABOUT box introduced · Driver for Bang & Olufsen approved wireless adaptor GN-WB31N is incorporated
· Flash Player 10 support · Status on Bonjour · Support for Russian (Cyrillic) character set · Improved internal logging for debugging purposes – for instance logging of received and issued Master-link commands
SW 5.03 -18/01/2010
Added : the BM5 can now display content to a link room TV !
Beosound 4 SW 2.15/1.31c - 7/12/2009, New functionality on A. MEM, new Features :
1. Compatibility with SDHC card (High Capacity SD cards 4 GB to 16 GB)2. Ability to start recording from remote control3. Ability to copy only selected tracks from a CD to the SD card4. The ability to make timer recording on SD card5. Ability to fast forward and back when playing from SD card6. Resume playback from the SD card after source change or turn off7. Compatibility with Master Link Gateway (redirection of light and control commands)
Beo5/Beo6 :
Latest config tool : 5.12Latest Beo5 firmware version :1.45bLatest Beo6 firmware version : 2.11a
Config tool 5.12 : - Support for 2-way mode for Beo6+Beosound 5Config tool 4.11 :- Support for Beo6
Config tool 3.87 :- Load previous local versions (going back to a working config)- Support for new Beo4 (type 1710) w. cursor control- Drag and drop of template logos- more than 200 PUC-Sources updated with cursor control- PUC-Sources are sorted by type and manufacturer- Correct channel step inside channels menu- Navigate to "Zones"- Navigate to "Setup mode"- Updated "Help"& some bug fixes
Config tool 3.59 :Bug fix from 3.57
Config Tool 3.57 :Firmware 1.45a- Battery drain bug correctedFirmware 1.42aBeoVision 7-55 addedBeoVision 10-40 addedBeoVision 8-40 DTV2 updateLogo templates for NorwayBeoSound 5 - RADIO and CD
Config Tool 3.23 :Beovision 6 26 changedBeovision 4 103EU added Config tool 3.00 :New installation
diisign.com
Normally everything there is up to date... Maybe I should erase some history, i.e. on the CTool for Beo5/6.
Can I suggest you also look HERE
Regards Keith....
As usual Keith, you make everything better!!
I just noticed that your software version for beovision 8/10 is at 210, where mine is at 224.
We now only need a place to display change logs, maybe here, and a place to speak about software news, issues and happy endings : here!
Maybe not better, but I do want to make it easy for members to find key information and then allowing certain groups (Founder and Gold members) to update it as it changes, hence why I have started the Technical Wiki's.
What you posted can be another page to that Wiki and there is no limit to the number of pages in any WiKi
mbee: As usual Keith, you make everything better!! I just noticed that your software version for beovision 8/10 is at 210, where mine is at 224. We now only need a place to display change logs, maybe here, and a place to speak about software news, issues and happy endings : here!
Just added your section to the Software version page as another page to the WiKi. Have a look and tell me what you think
Maybe we should split my big list with a wiki page for each product that has a software update history with change logs...
And if possible, the version number on the main page could become a link to the dedicated wiki page with history...
