Restoring the Beocenter 9500
This post has 29 Replies | 3 Followers
Mikael
Sweden
Posts 58
Mikael Posted: Fri, Sep 21 2012 5:10 AM
After getting help from you guys to bring my Beocenter 9500 back from the dead I have started to restore it into a good working condition.
So far I have tried to clean it up a bit. There are some major issues:
1.CD door does not close easily. It jams half way and you need to press the load button twice to get it to close or open completely. After cleaning the rails and lubing the brass axis I get it to function properly when the lid is in service position. The problem is when the lid is back in normal position. The the door engages the clamper arm (as it should) but it is not very smooth. You can actually see the whole CD mech move while the CD grips the arm and pull it into the open position. There is quite a lot of old grease on the underside of the CD door where the pin of the clamper arm engages. Should there be grease here? The servicemanual does a poor job explaining how to get best operation from the doors.
2. The lower glass panel is broken in two (surprise). I really need to find another one but 9500 ones are scarce. Does the 9300 work cosmetically? I understand that you loose the timer button. Have anyone tried one on a 9500?
3. Glass panels are loose. What kind of thickness is ok to use on the doubled sided tape to re-attach them? I have found one superstrong from Jula here in Sweden (a hardware store). It seams to be 1mm thick.
/Mikael
Beocenter Overture | Beolink passive | CX100 | CX50
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 21 2012 11:25 AM
I can only comment on Q3 - I took advice from the old forum and simply used super glue gel to fix the glass back in place.  I left the old tape in place, hence no messy cleaning required.  This has worked well for two BC9500s (and a BL5000 screen!)
I'll be interested in responses to Q1 as my mother in law's BC9500 has the same problem and I have tried extensive cleaning with no success.  I think the cord may need replacing as it tends to 'stick' on the rotating metal spindle whilst opening, and looks as if it should slide sideways to make room for more cord.
Re Q2 - perhaps a BC9000 panel will fit?  There are a few of those around cheap as the CD spindle breaks (unrepairably) rendering them less useful.  This of course does have the 'Timer' button.
root
Posts 226
root replied on Fri, Sep 21 2012 5:02 PM
1. replace the door belts, done in a minute, cost just a few bucks and are readily available from B&O. can't tell you anything about the grease though
2. use the glue that is meant for car windshields to fix the old one or ask beoworld member Leslie, think he's got some glass panels left
3. either reattach them the original way, double sided foam tape: http://www.ebay.co.uk/itm/Black-Super-Strong-Double-Sided-Foam-Tape-6mm-X-10m-/400243210944 that should last 10-15 years. If you want a permanent fix, above mentioned glue will do the job, the one for the windshields (not super glue, remember the ugly white residue it leaves?)
Mikael
Sweden
Posts 58
Mikael replied on Sat, Sep 22 2012 9:13 PM
Yes, replacing the belts is probably a cheap way to get better traction in order to move the doors. Hopefully there are some in stock at the local service center.
I have asked Leslie if he has a panel and are waiting for him to come back, but in case he doesn't have one then it is good to know my options.
Finally I have some pictures especially for Soeren (how do you make a danish oe on a mac keyboard) in Mexico:
The broken glass panel (sigh)...
The top stripped on all its panels. You can probably notice the long scratch on the CD door.
Some parts left to dry after cleaned with soapy water (they were really dirty).
/Mikael
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Sep 22 2012 9:22 PM
Mikael:
The the door engages the clamperarm (as it should) but it is not very smooth. You can actually see the whole CD mech move while the CD grips the arm and pull it into the open position. There is quite a lot of old grease on the underside of the CD door where the pin of the clamper arm engages. Should there be grease here?
Originally there was some grease, but it is now hard and sticky. The best thing to do about it is clean it away completely (do the same for the rails the lids move on) and relubricate with very little silicone grease. Apply with a cotton bud or something, never spray silicone directly on the target as it will get everywhere, even the places that should have friction.
Mikael:
Service manuals aren't usually too helpful with old age problems. They were written when the units were brand new! Smile
--mika
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sat, Sep 22 2012 9:26 PM
Mikael:
We had email contact but I was not aware that you needed one from me, sorry! Will check tomorrow!
Brengen & Ophalen
Mikael
Sweden
Posts 58
Mikael replied on Sun, Sep 23 2012 7:25 AM
Leslie: It is probably me that wrote a confusing reply to your email. No problems!
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Sep 23 2012 9:24 PM
Got one!
Brengen & Ophalen
Mikael
Sweden
Posts 58
Mikael replied on Mon, Sep 24 2012 4:43 PM
Leslie:
Got one!
Great! What would the beo community do without you Leslie?
I also visited my local B&O repair center today and picked up two belts for the doors. They were only like 5 Euros or so a picece. So it is really a no brainer, just replace the old ones. A tube of silicon grease was also purchased, hopefully that will do the trick.
Stay tuned!
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Sep 24 2012 8:17 PM
Mikael:
Hope that this will resolve your door problem but I'm afraid that it won't work. Most of the cases the rope or string becomes black and slippery and that's what causes this door problem. But still, you never know....
Brengen & Ophalen
Mikael
Sweden
Posts 58
Mikael replied on Tue, Sep 25 2012 10:14 AM
Leslie:
Well it sort of fixed the problems. Comparing the new and old belts was a revelation. The new ones were about an inch shorter so they really stretch over time. After installing them I would say the improvement on the door movement was moderate. But when I applied silicon grease to the rails with a cotton bud it really helped the door to go the whole distance. There is still an issue if the door open with a CD on the spindle. Then it stops sooner and does not go all the way. I am a bit reluctant to add silicon grease to the underside of the door where the clamper arm engage. Spreading the grease onto the CD mech is not a dream scenario.
Mikael
Sweden
Posts 58
Mikael replied on Wed, Oct 3 2012 7:45 AM
Picked up a package from Leslie today:
You guessed it right. It is the new lower glass panel. And with an unexpected bonus of new foam tape added.
Thank you Leslie!
I have also cleaned the upper glass panel from the old foam tape residue. Not an easy job but warm water made it possible to scrape it off with my fingernail.
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Oct 3 2012 10:13 PM
Happy it arrived safely!Smile
Brengen & Ophalen
Mikael
Sweden
Posts 58
Mikael replied on Sun, Oct 7 2012 8:00 AM
Leslie:
Mikael:
Actually you were right. The CD door has become worse and sticks. The cords are black and full of grime. I got tired and removed them. A stupid move maybe but I don't see another fix for the problem. The door moves like a hot knife through butter so theres no problem without the cord drive connected. Wish me luck putting it all together again.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Oct 7 2012 8:09 AM
Lots of patience is needed Mikael Super Angry. I did that excersise before, don't ask me how, but I did it! Typical sunday practiceSmile
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Oct 7 2012 8:12 AM
Don't take them both out or else you can't copy (mirrorized) if you know what I mean, unless you have more you units!
Brengen & Ophalen
Mikael
Sweden
Posts 58
Mikael replied on Sun, Oct 28 2012 1:44 PM
Leslie:
I actually managed to get the string drive back on. It was not so bad as I had imagined. Just a teaspoon of patience or two.
For you who are going to try this then the recipe is:
  • The key tools for success is masking tape and tweezers.
  • On top of that you need good light to illuminate your workspace. I used a cheap Ikea diode desk light with articulated neck that could easily be posed. Since every plastic is black you constantly need to move the light source to see what you are doing.
  • I could not find a suitable string so I simply reversed the existing one so that the white untarnished part now wraps around the brass shaft instead. The cord was in good shape but the best is to replace it of course.
  • Remove the center mirror panel (obvious maybe but anyway...)
The procedure i used to put the cord drive back on one side is:
  1. If boot strings on the door are removed, make sure it moves like a hot knife through butter. No use in putting in the work if the door cannot move properly so fix any rail or dirt/ grime issue.
  2. Study the picture in the service manual to understand how the cord drive works. The manual is pretty useless for servicing the string drive otherwise.
  3. Measure up the new strings to the old ones or just use the old ones backwards as I did. Make knots on the new string.
  4. Clean the brass shaft where the string wraps around. You do NOT want any grease on this surface. The string would slip in that case without the proper friction that you so badly need for the door to work right.
  5. Manually (push it with your hand) position the door in the close position. Make sure that the clamps running in the groove flips up to their closed upright position (also by hand).
  6. Manually push arm of the spring loaded pulley to its extreme and put masking tape to keep it there. You will need that slack it creates later.
  7. Now start with attaching the end of the string to the groove closest to the door on the clamp. This is a pain without a good tweezer to pick it up in the small space available. Attach it to the small grove so that the knot on the string sits firmly.
  8. Run the string around the grove on the clamp and then back to the spring loaded pulley (see picture in service manual). Just put it loosely around it.
  9. Then run the string back to the brass shaft and wrap it around exactly as shown in the service manual. The drive is a design by a genius (or a madman) so you need to get it right. I actually tried to wrap it one turn less than originally and that did not provide enough friction. Observe the difference between the two sides (they are mirrored).
  10. Attach the other knot to the remaining groove on the clamp.
  11. Switch to working on from the inside of the BC9500. Looking at the picture in the service manual and pull the string with a tweezer around the pulley next to the brass shaft. Remember the slack you created on the other pulley. Now you need that. Make sure the string runs in the groove of the clamp.
  12. Loosen the masking tape. Make sure everything lines up as in the picture and compare it to your other door.
/Mikael
Pestria
Posts 58
Pestria replied on Wed, Nov 21 2012 4:15 PM
How did you remove the bottom glass panel off the 9500?
(I have a similar problem with it 'lifting')
Thanks AP
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Nov 21 2012 4:24 PM
One screw from below left side.
Then slide the panel to the right a couple of cm's and lift it off.
Same goes for the upper panel.
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Nov 21 2012 4:44 PM
Great instructions Mikael! Yes - thumbs up Will follow your procedures soon!
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Nov 21 2012 4:57 PM
Pestria:
Thanks AP
For removing both lower and upper panels
Brengen & Ophalen
Mikael
Sweden
Posts 58
Mikael replied on Thu, Nov 22 2012 10:37 PM
So time for a small update. After fixing the door problem I started putting the unit back together again.
The top glass panel was really hard to clean up from all that stickey goo. The old foam tape sure left a mess. I ended up using medical benzine (used to remove surgical tape residue etc from skin) on the plastic rails that attach to the panels. Luckily Leslie sent me the lower glasspanel ready to be sticked on so that was easy. For the upper panel I used a double sided sticky tape from Jula here in Sweden.
So here it is:
Mikael
Sweden
Posts 58
Mikael replied on Thu, Nov 22 2012 10:43 PM
Leslie:
Just glad to be of help if someone needs this type of thing done. Good luck with yours!
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Nov 22 2012 11:14 PM
Mikael:
So here it is:
When you're happy I'm happy! Great result. For removing the sticky goo as you called it it's quite an easy task to remove it. Use a brush and some refined petrol or terpentine, brush it on the sticky "goo" a few times and within a half our just scrape it off with a soft plastic clip. Be carefull though with the black surface underneath and the grey conductive parts on the glasspanel not to scrape that off.  Be gentle.....The goo becomes gelly so quite easy to do. Same thing for the plastic frames. Check this on my webalbum to see how that looks like!
Brengen & Ophalen
markobeo
Posts 1
Thank you Leslie, My BC9500 didn't respond well to touch, had to press really hard on each command. It's also not fixed, moving left - right 5mm.
 I loosen the screw, took the panel out and put it back. When the screw is tight, it doesn't work. I'm fine with this, if there is better solution please respond. Greetings, marko
Die_Bogener
Posts 192
Did you remove every fingerprint on the backside? It does not like grease...
BazerLCGI
Posts 4
BazerLCGI replied on Sat, Apr 9 2016 12:16 PM
Had the same problem. CD door sticking, managed to regrease and working fine. My problem is that the door opens but the spindle motor starts to spin and the laser is trying to read a disc that is not there. It seems that the door is in the open position when it should be closed. Any ideas would be grateful.
Dillen
Posts 13,191
Dillen replied on Sun, Apr 10 2016 7:10 AM
Swap the two leads going to the door motor.
BazerLCGI
Posts 4
BazerLCGI replied on Sun, Apr 10 2016 9:46 AM
Hi Martin, that worked great. Common sense why that worked. Thanks for your help. I do have two LED not working on the CD numbers 6 & 7 next to where you press to change the tracks for the CD. I used a meter and they came on when testing. Any idea as they are next to each other. Cheers Barry
Dillen
Posts 13,191
Dillen replied on Sun, Apr 10 2016 10:11 AM
I've often seen cracked solder joints being the cause of intermittent LEDs.
On the LEDs themselves and/or on board connectors etc.
Page 1 of 1 (30 items) | RSS
