Cat 7 termination
This post has 12 Replies | 1 Follower
kai
Posts 362
kai Posted: Fri, Sep 21 2012 12:58 PM
Hi guys
What is the best one to use for cat 7 termination
Regards
Kai
Vienna
make an educated guess
Posts 1,090
Vienna replied on Fri, Sep 21 2012 8:30 PM
B&O and ATLONA (HD-Matrix recommended by B&O) use termination according to 568B for the best performance.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Sep 22 2012 5:52 PM
I get the termination. Ok.
Question of interest:: does the 568A or 568B differ from stability or performance?
Vienna
Posts 1,090
Vienna replied on Sat, Sep 22 2012 6:02 PM
ATLONA says, version "B" gives you some extra feet of usable maximum lenght.
Søren Mexico
Mexico City
Posts 6,411
Beobuddy:
Found this one
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Sep 22 2012 8:12 PM
Thank  you both.
Didn't know that just switching 2 colours could make a difference. I already use the 568B version. But start to doubt if I have used it consequently from the beginning. (from 2004 til now)
Start to wonder if (according to the mentioned link) mixing the 568A and the 568B in a network could cause malfunction like less performance in case of streaming full BluRay contents from server to mediaplayer despite the use of a gigabit router (linksys E4200) and gigabit switches.
But don't want to hijack this topic Wink
Søren Mexico
Mexico City
Posts 6,411
Beobuddy:
Its Cat 7, not hijacking, I think the only difference is how you have to twist the twisted pairs when connecting to the RJ 45 an/or the difference between STP and ScTP cables.
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Sep 22 2012 9:10 PM
Beobuddy:
Same difference if you run Ethernet on the cables.
But, if the cabling is used to deliver HDMI (as I presume the Atlona recommendation is about), the thing is a bit different. I'm not sure of the details, but I understand it has something to do with the signal routing from the female connector to the interface chips on the device PCB. In HDMI, the signals are balanced and at high bit rates timing (wire & trace length) becomes critical. 586A and B differ by which pair (green or orange) is split between pins 3 and 6, and I guess A is somehow worse for HDMI then.
--mika
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Sep 22 2012 10:11 PM
tournedos:
So, it comes down to the specs of the used signals of the connector?
Normally the twisted pairs are balanced and less sensitive for noise coming from outside the cable. So probably pin 3 and 6 are a TX/RX combination?
But still I'm surprised that a colour of a twisted pair inside a cable can make a difference. Both 568A and 568B uses pin 3 and pin 6 paired.
Or could (also) a possible mixe-up with crossed cables be the reason for standarding the colours? Using a several hundred metres cable, it isn't easy to check if you're dealing with a straight or crossed  cable.
But overall. Cat 6 and Cat 7 uses also 568B with just extra shielding which is connected to the shield of the connector.
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Sep 22 2012 10:46 PM
I guess it might have something to do with how the coloured pairs are physically arranged inside the cable - I'm not sure. But if a respectable manufacturer recommends one wiring order above another, I suppose there must be a better reason than simply the colour on the insulator Smile
--mika
kai
Posts 362
kai replied on Sun, Sep 23 2012 12:00 AM
Interesting comments I thought the only difference is one is the American way and the other is British as long as you follow the same wiring all the way through there should be no performance difference, I'm only going to be using the cable to run standard ml as that is all that is required at the moment but since this this was a complete rewire of the house thought I might as well be covered for the future, now lets hope that we can finally get a multi room audio from Bang & Olufsen :)
Vienna
Posts 1,090
Vienna replied on Sun, Sep 23 2012 9:59 AM
Beobuddy:
It's definitively not "the colour of the insulation" that's making the difference.
For varios tech reasons each of the 4 twisted pairs in CAT 7 cables is twisted slightly different.
More or less twists per meter of a pair will need a slightly different lenght of wires used for that pair per meter of the cable.
Sockets, plugs, and cables are all the same, it's ternination 568 "A" or "B" that decides which pair is used
to "transport" a certain part of the signal.
Vienna
Posts 1,090
Vienna replied on Sun, Sep 23 2012 10:34 AM
kai:
For replacing ML by CAT7 cables order the B&O / TYCO Cat 7 cable via your B&O dealer.
If you are going to use an other brand, it's mandatory the CAT 7 cable is specified as "S-FTP" = "Screened Foiled Twisted Pair"
The analoge ML signal needs that type of shielding / screening, especially in larger setups ...
Page 1 of 1 (13 items) | RSS
