beocenter 9500
This post has 10 Replies | 1 Follower
willbeocenter9500
Posts 7
willbeocenter9500 Posted: Fri, Sep 21 2012 2:40 PM
I have a beocenter 9500 and i can only get sound from the left speaker when i play the cd or radio , it works fine in both speakers when i play tape ! i have had a look inside for any loose wires blown fuses etc but cant see anything obvious , if anyone has any ideas it would be a great help ,
thanks
ps i have tried playing around with the balance , volume etc but it didn't seem to make any difference
willbeocenter9500
Posts 7
UPdate . After reading some posts i have taken the pcb 62 off and had a look at the soldering , c1 and c2 where loose so i have resoldered them and as many as i could on the rest of the board . once i have put it all back together now i get sound from my left speaker but only humming from the right one now !!??
 I have obviously done something to it when i dismantled it if anyone has got ANY  ideas i would be very grateful ,    thanks
willbeocenter9500
Posts 7
sorry i meant to say i am getting sound now from the Right speaker !!  which makes it all the more confusing as that was the speaker  that i was getting no sound from originally ??
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Sep 29 2012 8:48 PM
Does tape still work?
Peter
willbeocenter9500
Posts 7
tape still works , but only from right speaker . there is no sound from the cd or radio now .
willbeocenter9500
Posts 7
after reading some more threads on this forum , i think i might check the Capacitors on the board just next to the transformer , at least i think they are capacitors ?? , if anyone has any idea how i test them properly it would be of great help , Cheers
Mikael
Sweden
Posts 58
Mikael replied on Sun, Sep 30 2012 12:51 PM
I suggest you look into the service manual and locate where the different voltages connect to the pcb #60 with all op amps. Then follow each so that you get the right voltage span on the op amps. The service manual indicates what voltages you should expect. Then work backwards from there, checking the rectifier pcb etc if the voltages do not match.
Regards,
Mikael
Beocenter Overture | Beolink passive | CX100 | CX50
willbeocenter9500
Posts 7
thanks for the help , as you can probably tell im a bit of a novice when it comes to electronics so hopefully i wont blow it all up !!
Bob
Charente, France
Posts 418
Bob replied on Sun, Sep 30 2012 3:09 PM
No offence, but I would suggest having professional look at it, unless you're confident enough and have some electronic experience,  not objecting to follow the service manual and checking voltage etc on the other end Wink, but from my experience it would be simple enough for professional to rectify the problem (before any attempts has been made, than afterwards) and won't end up blowing it  Cool
Good luck, either way
bob
willbeocenter9500:
Don't worry - be Happy
Mikael
Sweden
Posts 58
Mikael replied on Mon, Oct 1 2012 5:53 PM
Hi, Ofcourse this is something that should not be attempted unless you know your way around electronics in general. A powered BC 9500 will have 220v around the PSU board. That shall be treated with respect if the unit is open in service position. So it is a matter of knowing your limits and then decide to have a technician look at it or not. Best regards, Mikael
willbeocenter9500
Posts 7
I checked the voltages on the pcb 60 and it didnt seem to tally with the manual so i think i might take it to a repair shop , thanks for all the advice , i will leave an update when i get it going , hopefully ! Smile
Page 1 of 1 (11 items) | RSS
