Hi
I would like to connect my LC2 to a LED lamp. I know that I have to change the LC2 setting to low-energy light. I tried it with this manual: http://www.iconic-av.co.uk/manuals/LC_2_English.pdf
But if I press a number I can still dim the light. I also tried it with a Beolink 1000. Is it possible that some LC2 doesn't have low-energy light feature?
LC2 can`t work as a dimmer for LED lamps. The programming you described converts LC2 into a switch.
Did you touch the black dome while programming the sequence?
Stefan
Yes I just want to use it as a switch. So just on and off function.
No I did not touch the black dome. Do I have to do that? ;-)
