Replacement bass woofer for Beovox S45-2
This post has 1 Reply | 0 Followers
Unifaun
Posts 1
Unifaun Posted: Tue, Sep 12 2017 12:44 PM
Hi!
I bought a second hand pair of Beovox S45-2 and it turns out one of bass woofers are stuck! Either the seller didn't inform me, or perhaps it was broken during transport. I've read that they can be quite fragile.
I was thinking of trying this fix: http://archivedforum2.beoworld.org/forums/p/23102/193118.aspx
But my expertise and equipment are a bit too limited for such a project.
As such, I was wondering if anyone knows where I could find a replacement bass woofer? This means I could ask the seller to cover the cost of one for me, and I should be able to solder it in place quite easily myself.
All the best,
Markus
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sun, Sep 17 2017 2:40 AM
Where are you located? If you are in the States, I would be happy to try to fix your stuck woofer.
Page 1 of 1 (2 items) | RSS
