Beosound Moment+Deezer or Aries+Tidal into Beolab?
This post has 11 Replies | 1 Follower
seethroughyou
UK
Posts 999
seethroughyou Posted: Sat, Sep 16 2017 9:35 AM
B&O recommend either the Beosound Moment+Deezer or Aries+Tidal into Beolabs. Has anyway tried either option or both options and have any advice or observations?
The Moment is £1795
The Auralic Aries if £1495
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
seethroughyou
UK
Posts 999
Of course the other option is a Beosound Core but you don't get the Moment's mood wheel...
Duels
England
Posts 2,553
Duels replied on Sat, Sep 16 2017 10:15 AM
seethroughyou:
That is true although there is plenty of opportunity within Spotify for example to pick music according to mood. I struggle to see the need for the Moment for streaming unless it is just the appeal of something physical from B&O.
seethroughyou
UK
Posts 999
I never thought of this point.
Are you saying the Moment is redundant because most streaming services offer mood based playlists?
Duels
England
Posts 2,553
Duels replied on Sat, Sep 16 2017 12:32 PM
From my perspective very much so, yes. There are loads of genres and moods available some even reflecting the day if the week (i.e. Lazy Sunday afternoon tunes). I'm using Spotify almost exclusively now.
seethroughyou
UK
Posts 999
Ive heard that the Moment isn't as yet equipped to handle high resolution files like 24bit 96kHz but the Core is?! How strange is that, so the Core which is quarter of the price can...
Millemissen
Flensborg, Denmark
Posts 14,680
Specs of the BS Moment
Music formats
MP3 (all) or VBR / CBR 32 – 320kbit
WMA, both VBR and CBR 20 – 320kbit (No support for WMA Lossless)
AAC (ISO and ADTS) – 320kbit
ALAC general + 88.2, 96 kHz
PCM (WAV) general + 88.2, 96 kHz FLAC, 8–96 kHz, 16 or 24 bits, 2 channels
What are you missing?
seethroughyou
UK
Posts 999
The most commonly used lossless format that's open source: FLAC.
Sweden
Posts 357
Silver Member
Martin replied on Sat, Sep 16 2017 5:38 PM
Hi
i have the auralic Aries with digital feed to my Beolab 5. This is the best product I ever own!!  The audio qualityis much much better than
Beosound 9000 and Beosound 5 with digital feed to labs 5. I highly recommend the Airies to everyone.
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
seethroughyou
UK
Posts 999
Heard others say that.
Why would an Aries be better than a Beosound as both output 1s and 0s and the digital conversion is done in the Beolab 5?
Millemissen
Flensborg, Denmark
Posts 14,680
Good question - let the guys give an answer to that ;-)
seethroughyou
UK
Posts 999
Been reading other forums and the consensus is that different digital machines shouldn't make a jot of difference. Someone gave the example of you accessing your accounting spreadsheet from your NAS on the other side of the world; the 1s and 0s pass through millions of switches, relays, microwave links, satellites, substations, underground cables and prone to solar flares, EM interference in switching substations etc. but your accounting spreadsheet always arrives in perfect form - you haven't dropped a 1 or 0 suddenly and sadly not gained any extra zeros. They say that digital streams are now so robust it's not worth worrying about. The only people that maintain some difference are the audiophile type. One person I read about, actually tested two different NAIM streamers (base model vs top-end) reading the same NAS and outputted them to the same DAC and couldn't tell the difference. Happy to stand corrected.
Page 1 of 1 (12 items) | RSS
