Is this a powerlink cable?
This post has 2 Replies | 2 Followers
MJBeo
Netherlands
Posts 270
MJBeo Posted: Tue, Sep 19 2017 4:54 PM
Hi all, I bought a bunch of MCL cables from ebay, and there is one 6-core cable that was used as a MCL extension cable between two wall plugs. Would I be able to use this as a MK 2 powerlink cable?
Alternatively, would a MCL cable work as a powerlink MK2 cable if I connect a DIN8 plug? The only difference between the two cables that I can see in the MCL handbook is the additional shielding around the left and right signal. I did not want to open one of my powerlink cables to check the inside.
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi MJBeo,
That looks like it could be caravan/trailer lighting cable connected to an 8 pin DIN plug!  It may function for Powerlink (depending on how it is installed), but there doesn't appear to be adequate shielding around any of the wires for audio use.
I can provide the correctly shielded Powerlink cables if you want to be sure of good sound:-
http://soundsheavenly.com/44-powerlink-8-pin-din-connection
Kind regards, Steve
Steve.
www.soundsheavenly.com
MJBeo
Netherlands
Posts 270
MJBeo replied on Tue, Sep 19 2017 6:13 PM
Thanks Steve for the quick reply!
Page 1 of 1 (3 items) | RSS
