Why has the Beoworld iphone app stopped working?
I cant post any replies or new discussions. I have had to resort to sitting in front of a computer which feels like the 1990s.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Same here (iPhone 5s iOS 11.0)
May this be caused by the iOS update ?
Did you update to ios 11.0? With ios 11.0 Apple stopped support for 32bit apps, only 64bit apps work from now on. So maybe the beoworld app is 32bit only...
.b
By the way - is the Beomusic app 32 or 64 bit?
The Beoworld app runs correctly (apparently), except that once you send your message, it does not appear on the forum. There's no error message neither.
The last release of the Beomusic app is called "Musique" in France now. And it's running with iOS11.
EDIT : Editing within the Beoworld app is also not functioning.
I used my Android tablet to post and edit this message.
The Music app was updated for the Android platform too.
CB: The Beoworld app runs correctly (apparently), except that once you send your message, it does not appear on the forum. There's no error message neither.
I can confirm that the posts don’t go to moderation either. The same thing happens on my piePhone 5 (obviously on ios10) so it doesn’t have anything to do with the latest ios update.
The app is not provided by Beoworld so I don’t think we can do anything about the problem, it’s up to the author.
--mika
Hi All,
A few things change each time the forum moves to new servers, so the app needs a small update.
I submitted a new version to Apple just a few minutes ago, but it'll take a few days to go live.
If some of you want to test the version before it's released, send me your email address by private message.
Philippe
Beoworld app with direct photo upload and emoticons.
Thanks a lot Philippe for your great work !
I still can't edit my messages Phil...
Jacques
The app has been approved now and the update should appear any time soon.
I did the update very quickly so let me know if anything is still broken.
Also, I have not tested the Wednesday forums, so it'd be worth checking if the app still works on them.
p.
As mentioned above, no edit button appears.
Same here with the last release (v5.5)
I think it’s because we have to log in, but it’s not possible to enter our login/password
Another version is available for download : v5.6
I'm still not able to log in with it
I deleted it and dl it again (several times, using various methods and tools) without improvement.
The fields Username and Password are not editable (the keyboard does not appear).
New version works for me!
Still not working for me I’m afraid to say.
This thread is now LOCKED please report issues with the iPhone/iPad App on THIS THREAD
Regards Keith....
