Masterlink in 2017?
This post has 21 Replies | 1 Follower
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Steve at Sounds Heavenly Posted: Wed, Sep 27 2017 2:07 PM
Hi everyone,
As you may know, we have been assembling Masterlink cables to order for over a decade now and it has been interesting to see how popular this early 1990's connection has remained over the years.
From the original CRT Avant TV and Beosound Ouverture in 1994, Masterlink became the mainstay of B&O networks for almost two decades, finally ending up in the Beomaster 5 and Beovision 10 TV until 2013.
I would be interested to hear from fellow Beoworlders as to whether Masterlink still works for you in 2017 and for the future - do you still use it to send music around your home?  If you moved house next week, would you install a new ML network in your new home?
As an example, I use an ever older (pre-ML) Beosystem 3500 at home, linked via an ML/MCL Converter to two Beolink Actives and two Beolink Passives to give me remote controlled access to CD, radio and vinyl records across 5 rooms of the house.  I would probably set up the same system again straight away if I were to move house.
I aim to have Masterlink cables available for many years to come, so I would be interested to hear your thoughts on how/if you plan to use ML products in the future.......
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Sal
California, USA
Posts 1,197
Sal replied on Wed, Sep 27 2017 3:48 PM
Although I currently only have NL products. I used to have a small ML network in my old apartment: BeoVision Avant connected to BL3+2 and a BS9000 in one room, and BS4000 in another room. What I found with ML was that it just worked. It always did what I expected it to do, and how I expected it to do it. NL is great. Cabling is easier than ML, and one can use "standard" ethernet cables (you know what I mean). However it is somewhat clunky in implementation. For example, I don't want my BV11 screen to turn on at all for whatever reason when I want to listen to music via it's connected speakers.
Steve, I think all of us and B&O should thank you and your business for doing the things you do that allow us to enjoy our products more fully and easily without fear of scarcity of finding cables for our systems.
To answer your question -- for me a thought experiment since I don't have ML products any longer -- If I did, and I was moving house, I don't think I'd have ML installed in the walls, purely because it is an obsolete framework. I'd want a new house, to be equipped with current technology and frameworks. However, if I had a many ML products, wired and linked together in expert fashion like beojeff, my opinion would be different.
olvisab
Posts 1,391
olvisab replied on Wed, Sep 27 2017 8:58 PM
Hi steve,
little ml network in 3 rooms (main room, room, kitchen, mlgw). I still love it for its simplicity, reliability and flexibility. I don't miss the new capabilities of the nl. When I see the multiroom issue with player and video, I am glad to rely on this old system.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Kromer
Randers, Denmark
Posts 129
Kromer replied on Wed, Sep 27 2017 9:03 PM
For me the short answer is yes i will. I'll be installing Master link to 5 rooms this weekend :-)
I Think that for many of us B&O is very much about the heritage products from 'the good old days', and for the masterlink era it's just an integral part of the systems. So for the full experience of these system alone I think it's worth it.
I have both ml and nl products in my system and at the moment I Think ml still has some advantages. It's reliable, simple to use and without delays. I'm sure nl/multiroom is going to be great but then ml can be integrated. Which is a stroke of genius really. I mean I have Essence internet radio available on an early 90's system with a single touch of the remote.
I'll be using ml with 6500 via blc 1611 as Master and linked rooms with bl2000, bl3500, bs3000, bl passiv, and a not yet decided beovision. I'll be open for replacing bl2000 and bl3500 with future nl products but there are non now that I'ld rather have and it just works. Mainly we just use it for every Day stuff like listening to news from the tv while in the kitchen or radio in a couple of rooms . Simplicity of use and reliability is key here.
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, Sep 28 2017 8:40 AM
As the others have said ML is simple to use and just works, it's easy to link products and sound quality is excellent, plus if you already have a number of B&O products you are likely to take them with you when you move. I use ML to link all my stuff together and I have integrated my main listening system which isn't B&O into it via Beolink COnverter and a lintronic box.
At the end of the day if you just want to listen to the radio or pipe music it is so easy at the push of a button rather than getting your phone out and joining etc. etc.
LarsJensen
Posts 35
I just recently got my first NL product (BeoSound Moment and I LOVE IT) and installed the NL/ML converter to connect it to my existing ML network (And I love the integration as almost much as I love the BeoSound Moment).
From now on I will probably only be adding NL products and replacing existing ML products but I will keep some ML products for years to come – if I will ever part with them.
So yes, for me ML will live on and I too love its simplicity and reliability. But honestly connecting NL products to your existing switch via Ethernet is pretty easy to – given you have an infrastructure in place.
/Lars
Master123456789
Posts 237
I still love the design of the Beovox cx50 and Beovision 8, and there are not a NL product (speaker) where I like the design that much yet. Also I still love to turn on the radio with a simple push on the beo4/beolink 1000 remote - easy and simple.
I have bought a Beosound Essence and this can be added on my old masterlink setup with the beolink converter ML/NL. Very nice! I hope in the future the beolink converter ML/NL gets cheeper, I can buy more of these and then I can make all my old ML products wireless.
Right now I have the masterlink cables installed, so I have not intention of removing them. But if I someday moves to another apartment or house, I will maybe look at alternatives. I must say that it have always annoyed me, that the masterlink cable are so thick!
To sum up - I still love to use the beo4 to control the music, and cables are the best for the most stable connection. And the old design ofen still are most nice.
folkdeejay
Posts 96
folkdeejay replied on Thu, Sep 28 2017 10:43 AM
Steve at Sounds Heavenly:
Hi everyone,
I have 5 ML 'zones' cabled up - linking Bsnd 9000 and Bv5 in one room, then four link rooms (one is the garden!)  all hardwired via ML.
Would I add to this with more ML and Beolink products ?  Potentially, yes.  But probably only if I bought a supercheap link speaker.
Would I move and re-cable using new ML?   No.
Aside from not planning to move, the wireless options and verbal interfaces are too tempting.
So a new property would not be fitted out with ML - with the one proviso that if there were some easy (back to back or wall void drops) cabling routes, I would maybe plumb in our 3500/2000/passives with speakers...   but as 80% of what they do is R4, R2 and Spotify  - and then a few CD's -   I would go wireless I think.
Maybe even using Amazon stuff for secondary rooms.  My Amazon Echo sounds as good as my Blab2000, and I can talk to it!!
benjnz
Posts 114
benjnz replied on Thu, Sep 28 2017 2:48 PM
A big thanks to Steve for still supplying ML stuff. For me I have a mix, main room have NL, and then I have two seperate ML one in a bedroom and one in the kitchen, they’re not linked but one day I’ll get round to linking up the two ML rooms.
I’ll keep the two seperate until overtime the ML products die and I replace them with NL. Being in NZ there no chance in hell for repair as service is non-existent.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Sep 29 2017 7:43 AM
Back in 2004 we installed CAT7 as network cabling.
Made the mistake not to have the best shielded version installed - but still it work with RJ45 plugs / ML plugs for Masterlink.
Powerlink with RJ45 does not work in all rooms because it seems to be more sensitive to the unshielded cables :-(
So - for Masterlink - CAT / network cabling is the way to go today.
Sure you still need the cables with RJ45/ML plugs,  so Steve is still in the game ;-))
Ralf
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Sep 29 2017 11:05 AM
Hi Steve
I will be using ML for some time to come, at least until all the ML stuff I have fails - quick, reliable, easy to install but most importantly the quickest and most convenient way to listen in to music playing elsewhere that doesn't require constantly having your phone with you or wireless connection.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 29 2017 11:19 AM
My house in UK is still wired for MCL, but I'll probably 'update' to ML if/when I move back there! Smile
Bertrand
Posts 11
Bertrand replied on Fri, Sep 29 2017 11:47 AM
Je suis en ML de la pièce principale entre le BeoVision 10mk3 et le BeoSound 9000mk3 puis dans deux autres pièces avec une BeoLab 3500mk2 et une BeoLAb 2000mk2.
C'est un système très simple qui me convient parfaitement et en cas de déménagement je ne changer rien.
J'aimerai bien un BeoSound 5 encore mais il me semble que le ML ne fonctionne pas avec lui ?
Posts 2,165
Thanks everyone for all your replies and kind words Smile
Guy:
Glad I'm not the only one who still has MCL at home Whistle so this leads to another question: should I look at getting the "obsolete" MCL cables made again?
Steve.
jamesfl99
Posts 3
Silver Member
jamesfl99 replied on Fri, Sep 29 2017 1:08 PM
I also still have an MCL based system used every day. Feeds from a 5500 system in the lounge to the kitchen, bathroom and main bedroom.
In fairness it is brought up to date by the use of a Bluesound Node which distributes music from a hard drive, connected via the Tape 2 connection into the MCL but can then be accessed via phone/tablet around the house.
All good! James
DMacri
United States
Posts 881
DMacri replied on Sun, Oct 8 2017 5:41 PM
I still have MCL in my house and I would add it to future house because I still love the old B&O passive speakers and the ability to run multiple rooms with the same signal. The fact that it a high level signal that seems immune to low level noise helps.
As a matter of fact, I plan to order a set of Speakerlink cables from you shortly for my Pentas.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Posts 2,165
Thanks Dom!
Interest does now seem to be waning in the MCL systems, but the good old Penta speakers are still going strong in many homes!  I am pleasantly surprised at how many sets of the 4 pin Speakerlink cables we ship every month, good to know that these lovely speakers are still being enjoyed.
Steve.
Johan
Bolsward, NL
Posts 450
Johan replied on Sun, Oct 8 2017 7:52 PM
Hello Steve,
My usage of Masterlink is similar to yours: the BeoMaster6500 is MCL connected to a converter. The ML goes to a junction box and on to the kitchen where a BeoLab 3500 is bringing the music.
I enjoy the perfectly working multiroom technology from the ‘90s everyday!
regards, Johan
Beolab1
Rotterdam
Posts 22
Beolab1 replied on Tue, Oct 10 2017 3:00 PM
Well Steve,
I just moved from from Asia to London and have been on a Masterlink bonanza! I still really love the fact that you can cut the cable, split it and solder it together, adding more Beolink products. To my joy, I discovered a Masterlink cable and RF cable when I took out the old carpet in our new place. They turned out to be running from living room through kitchen & bathroom to the bedroom. Thanks to who ever put that in!
With some of the cables that I ordered from you and cable bits I still had, I have set up my Beovision 10-40, connected to my BeoSound 9000. I took my Beogram 7000 and Beocord 7000 out of storage and used your splitter cable to connect them to the AUX. Two Beolab 6000 and two Beolab 4000, with a Beolab 11 complete the living room.
I took my 2 Beolab 2000’s out of storage as well and got a 3rd one from LifeStyle AV. They are now in the kitchen and both bathrooms. To complete it all, I got a Beovision 6-22 on a motorised stand to put in the bedroom. Now I have music throughout the apartment and can even watch and control digital tv and Netflix over the RF cable in the bedroom.The simplicity and reliability of Masterlink is just great. Some of my cable pieces are from 2000 and still perfect.
I would certainly put Masterlink in another apartment if I were to move again!
Mogelmose
Posts 88
Mogelmose replied on Tue, Oct 10 2017 8:18 PM
I have sold all my MCL and ML units except my Beomaster 6500 and Beogram 7000. They are setup with a 1611 and NL/ML Converter.
I love my datalink gramophone playing in every room of my house controlled via Remote or App from any room in the house.
Stones
Posts 59
Stones replied on Tue, Oct 17 2017 7:38 PM
I built a new house three years ago and installed ML. ML products are still available used to an ok price. I would however not put ML cables in the wall today, but use CAT7. Such a solution is much more flexible and future proof. For ML products I would then ask for a RJ45 to ML cable for the connection.
Bart
Mallorca, Hamburg, Billund
Posts 15
Bart replied on Fri, Mar 23 2018 9:59 AM
As far as the standard... there is no such thing as unshielded Cat7.
Bart
BL8000, BL8002, BL4000, BL3, BL12.2, BS5, BS7000, BS9000, BS9500, BS2000, Ouverture
Page 1 of 1 (22 items) | RSS
