PUC and Apple TV 4K
This post has 10 Replies | 1 Follower
Jan Præst
Denmark
Posts 34
Jan Præst Posted: Fri, Sep 29 2017 7:21 AM
Where to place the PUC on the new ATV 4K? Are there any good suggestions?
Regards
Jan Præst
BeoLap 17, BeoLap 3500, Beosound 35, BeoSystem 4, BeoPlay A2 Active, Beovision Eclipse 55, Beoplay E8 2.0, Beolap 19
Aussie Michael
Melbourne, AU
Posts 3,730
I placed mine exactly where i placed it on the ATV4 and it works
When you turn it on you will see the little light on the right hand side, so over that :-)
andersenpost
Posts 18
Anyone who can guide me on how to pair my Beo remote One with the Apple TV 4k ? it worked with ATV3 - I just switched to ATV4K and now i cant use my beo remote for my new ATV :( please help
Jan Præst
Denmark
Posts 34
I did the same but from ATV 2. gen. I just used the same entrance on the Avant and change the PUC protocol to ATV 4. gen. And it worked...
Regards
Jan Præst
andersenpost
Posts 18
Hej Jan,
kan du hjælpe mig med hvordan jeg gør dette ? jeg fik B&O til at sætte det hele op første gang til - så jeg ved ikke hvordan jeg ændrer PUC koder osv :)
Millemissen
Flensborg, Denmark
Posts 14,680
andersenpost:
Hej Jan,
Which tv do you have?
If a newer one, you can download the new/the ATV4 codes and use these instead - see User Guide for howto.
if an older model, your dealer will have to upload new PUC codes to it.
But honestly, I would not spend that money - the old/the ATV3 codes works, but with some limitations for the ATV4 as well.
Just place the ir-emitter on the new ATV box (....and the HDMI cable).
Jan Præst
Denmark
Posts 34
Jan Præst replied on Thu, Oct 12 2017 10:58 AM
Jf. svaret nedenfor. Via Avant'ens insdtillinger kan man hente ATV4 settings og efterfølgende knytte den til den HDMI-adgang, som ATV'et hænger på.
Regards
Jan Præst
andersenpost
Posts 18
Hi my tv is beovision 14 55".
Millemissen
Flensborg, Denmark
Posts 14,680
andersenpost:
Fint - du kan så bare hente koderne selv - følg opskriften ovenfor hhv i tv'ets brugervejledning på side 88/89.
tigerisak
Posts 124
tigerisak replied on Fri, Oct 13 2017 9:43 PM
Trying to get this to work on my brand new Beovision Eclipse. Got it connected to PUC 1A and HDMI A. The PUC is set on Apple TV 4th Gen. But cant seem to get it to work. Got an Beoremote One BT (the one without Netflix).
Anyone?
SBMadsen
Posts 5
SBMadsen replied on Fri, Nov 17 2017 10:03 PM
Is the PUC ir code for TV/Home messing? (To see your recently used apps, by double press TV/Home.)
if NOT where to find on BeoRemote one BT ? (Got the Eclipse and apple tv4k)
Only works if you pair the BeoRemote with BT on the apple tv(then it’s the INFO button), but then i loose the control over the Eclipse
https://support.apple.com/en-us/HT205305
Page 1 of 1 (11 items) | RSS
