BeoSound 9000 and Beo4 compatibility
This post has 23 Replies | 2 Followers
aedellis
Posts 9
aedellis Posted: Sat, Sep 30 2017 8:49 AM
Dear friends greetings from Greece.
I own a perfectly working second-hand BeoSound 9000 with BeoSound 8000 loudspeakers for about a year.
Recently, I purchased a Beo4 from Catawiki. Unfortunately, it does not work with my system. I checked Beo4 IR "eye" with my smartphone and it blinks. Furthermore, there is a very large plasma TV in close proximity that is now switched off.
However, there is no improvement.
I am very disappointed and I am asking for your help.
Sincerely,
Thanos
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 30 2017 9:00 AM
Good morning from Bucharest!
It's good that the Beo4 does in fact transmit.  Did you try my other suggestion about checking the A.OPT setting?
There is another possibility, that the Beo4 is set up to be a LINK remote.  Try this on the Beo4:
Standby + List together
Press List till CONFIG appears
Enter 2002 , the display may read LINK ON, or maybe LNK OFF.
Press Exit
Repeat the process to make sure the Beo4 display reads LNK OFF.
aedellis
Posts 9
aedellis replied on Sat, Sep 30 2017 9:09 AM
Dear friend,
it was at LINK OFF mode, I switched to LINK ON and again to LINK OFF, to make sure it can be done.
Nothing happens...
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 30 2017 9:16 AM
Hmmm.  I have just been looking at the Service Manual on line - avail to paying forum members.
It seems that the BS9000 should automatically change to A.OPT 1 when Powerlink is connected (to your speakers)
Try:
- Unplug the BeoLab speakers from the connection panel on the BS9000
- Power it on and then off again.
- Reconnect the speakers and try again.
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 30 2017 9:21 AM
Otherwise, re-try that Option setting process that I described in the other thread, but substitute '1' for '2' at the last stage.  i.e:
With the BS9000 powered up but not switched on, press the Power off (red) button and LIST together on your Beo4.  The remote will display ADD?, whereupon you press LIST until OPTION? is displayed.  Press GO and the display changes to V.OPT. Press LIST to display A.OPT.  Press '1' and the power LED on your BS9000 should flash to acknowledge, and hopefully the remote should now work.
aedellis
Posts 9
aedellis replied on Sat, Sep 30 2017 9:39 AM
Dear Guy,
I un- and re-plugged loudspeakers to Powerlink (is there any difference between the two Powerlink ports by the way?), but nothing happened. In turn, I followed your steps at A.OPT but nothing happened again.
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 30 2017 9:52 AM
Oh dear.
Sorry but I have run out of ideas - hopefully someone else will see this thread and come up with some other suggestions.
Otherwise, do you know anyone who could lend you a remote, or could you test your remote with someone else's system?  A visit to a technician may otherwise be required.
(There is no difference between the two PL ports)
aedellis
Posts 9
aedellis replied on Sat, Sep 30 2017 12:37 PM
Unfortunately there are no friends with B&O systems, they are still very expensive systems in Greece. The problem is that even the B&O official representatives in Athens (capital city of Greece), do not further support service for BS9000 MKI, so I cannot have any official help.
Do you think it might be a problem of IR receiver of BS9000? Is there any chance to confirm it or evaluate it?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Sep 30 2017 1:08 PM
aedellis:
Dear Guy,
So, did BS9000 led flash while you were executing option setting as Guy wrote?
How did you control your BS9000 before you bought the Beo4? And did everything work properly?
Are you using original Powerlink cable?
Did you try to clean the BS9000 near the IR receiver?
Stefan
aedellis
Posts 9
aedellis replied on Sat, Sep 30 2017 1:28 PM
Dear Stefan,
the BS9000 led did not flash in any case, unfortunately. I controlled my BS9000 manually, using its control panel; everything was perfect.
Powerlink cables for BeoSound 8000 cables are the ones in the original package.
Regarding the BS9000 IR receiver, I have not tried to clean it (it is located next to stand by button, isn't it?), but it looks clean.
Regards,
Thanos
stefan
Posts 2,920
stefan replied on Sat, Sep 30 2017 2:04 PM
If the BS9000 did not even react to option setting commands and the receiver is clean, the ir receiver might be faulty. But first I would check the Beo4 with another Beosystem. Maybe there is a Beoworlder in Greece who will test it for you? You could send it to me, but it`s a bit far I`m afraid... Another option can be to buy a (very cheap) BL1000 and test your BS9000. If the IR receiver is faulty and it can not be repaired there might be a workaround with a Beolink active.
You can connect a BL active with ir receiver via Masterlink to your BS and connect the BL8000s to the BL active. Now you can control the BS9000 with a Beoremote through the BL active.
Stefan
aedellis
Posts 9
aedellis replied on Sat, Sep 30 2017 3:53 PM
Dear Stefan,
as I can understand if BL1000 functions with my BS9000, then then IR receiver is working, correct? So, I have to find a BL1000, for the beginning.
Regarding BL active: Do all BL active have IR receivers? In this case, if my Beo4 functions (I have tested my Beo4 IR "eye" with my smartphone camera and it blinks- I presume it functions), I am going to use BS9000 with BL active IR receiver?
Practically, I connect a functioning IR receiver to BS9000, don't I?
Regards,
Thanos
stefan
Posts 2,920
stefan replied on Sat, Sep 30 2017 6:41 PM
- correct.
- bl active is a black box with ml- poerlink- and IR sockets. IR receiver is an extra device.
- yes.
- yes.
Stefan
aedellis
Posts 9
aedellis replied on Sat, Sep 30 2017 6:48 PM
Dear Stefan,
I do appreciate your help.
I hope I solve it.
Regards,
Thanos
stefan
Posts 2,920
stefan replied on Sat, Sep 30 2017 7:47 PM
I'm pretty sure, there is a solution. Keep us informed - good luck!
Stefan
Bertrand
Posts 11
Vous pouvez également tester le faisceau infrarouge de votre  Beo4 avec l'appareil photo d'un smartphone pour voir si la Beo4 fonctionne.
Vous mettez l'appareil photo devant la Beo4 comme pour la photographier et vous appuyez sur les boutons de la Beo4 et si elle fonctionne vous verrez les diodes émettrices de la Beo4 qui vont s'allumer.
De ce fait vous pourrez être sûr que votre télécommande fonctionne ou pas.
CB
> You are Here <
Posts 1,762
CB replied on Sun, Oct 1 2017 2:07 PM
Bonjour Kappler,
Bonne idée, mais Thanos explique dans son premier message que c'est ce qu'il a fait, et que ça fonctionne.
Bertrand
Posts 11
Zut j'ai loupé un épisode, désolé
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
KAPPLER:
ENGLISH in the GENERAL Forum please
Regards Keith....
marexy
Posts 710
marexy replied on Mon, Oct 2 2017 8:17 AM
Many times problem with BS 9000 MK1
been there ..done that ...several times ..
https://fl0rian.wordpress.com/2016/05/29/beosound-9000-ir-receiver-repair/
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Oct 2 2017 9:41 AM
just a thought: do all types of PL cables switch the BS9000 mkI to option 1? if not than maybe using other cables would do the trick
stefan
Posts 2,920
stefan replied on Mon, Oct 2 2017 12:49 PM
Yes. Powerlink detection for A.OPT 1 is done by PIN 4 - available in all Powerlink cables. Btw had Thanos tried to set audio option to 1 manually, and the led didn`t respond.
Stefan
aedellis
Posts 9
Thank you all for your help.
I am scared opening and trying to fix IR receiver by myself.
I prefer trying a BL1000 or another Beo4 instead or at least initially...
Beobuddy
Utrecht, The Netherlands
Posts 3,972
For fixing or replacing the ir-receiver (they are still available if you're not capable of soldering), you need to take off the glassdoor, topcover and some screws on the bottom. Then you need to lift the aluminum plate to get acces to 2 screws from the ir-pcb.
Tricky part will be sledge, small flatcables,  springs, etc.
Page 1 of 1 (24 items) | RSS
