Hi all,
I've read about my problem but found no solution.
I can turn on the tv from the remote, TV symbol shows at top of screen, but all that happens is the screen changes to a dark grey like a backlight has come on. DVD works from remote, I can hear the disk spin up but no picture.
Any basics I can check myself?
Any good independent service guys out there in the uk I could contact? My local B&O centre were sympathetic but understandably just want to sell me a new tv.
Any help appreciated,
Stuart
First place to check is the PSU PCB.
Then the T-CON PCB
And finally the Inverter PCB
Contact me directly (Contact member) to send me pictures of the PCB's, and I'll be able to help.
I have the same issue, how can it be fixed?
Do you know if parts are still available for the beovision 7-40 mk6 type 7744? I think o need a t con
Send pictures of the PCB's to yachadm AT gmail DOT com
Isn't the T-CON part of the panel on the Mk6?
On T-con module is a tiny fuse 'CP' that can be the problem.
It is possible to repair when having removed the metalcover from the T-con module.
Can you send a link to a picture of the T-CON module please?
