Hello,
Beoplayer app has been updated.
Unfortunately, I had to uninstall then reinstall the app and my favorites are gone.
same for you?
Kind regards,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
YannChris:Hello, Beoplayer app has been updated. Unfortunately, I had to uninstall then reinstall the app and my favorites are gone. same for you? Kind regards, Yann.
Beste Grüße / Best regards
Schlaumeier
Setup Livingroom: BeoVision 10-40 and 10-32, BeoLab 6000 front, BeoLab 4000 rear, BeoLab 11, Ouverture, Apple TV 2 & 4, Airport Express, 6 x LC2.
Other Rooms: 3 x BeoSound 8, BeoVision 8-26, MX 4002, 2 x Keyring, 2 x Beolit 15, A1, Airport Express, 4 x Beo4, 2 x Beocom 5
No upgrade issue - just happened and now is stable
I don't have a list of favourites on my iPhone so can't check that
I upgraded the version on the iPad that has favourites (but did not have a problem because the iPad 1 can't run iOS6) and it had no problem with its favourites on any functions
BeoNut since '75
Schlaumeier:... it doesn't work properly. tried to delete a favorite. this shot down rhe app. Beste Grüße / Best regards Schlaumeier Setup Livingroom: BeoVision 10-40, BeoLab 6000, BeoLab 11, Ouverture, Apple TV, Airport Express, 5 x LC2. Other Rooms: 3 x BeoSound 8, BeoVision 8-26, MX 8000, 2 x MX 4002, 2 x Keyring, Airport Express
Working flawlessly now! Allows me to delete a favourite etc. No problems! Nice to have my French radio again!
personaltrainerpaul:Working flawlessly now! Allows me to delete a favourite etc. No problems! Nice to have my French radio again!
No Michael RJM 80s :) I think you may like!!! :)
Paul W:Working flawlessly now! Allows me to delete a favourite etc.
Working, yesflawlessly, no!
You are able to delete "working" stations - but you can't delete an empty entry in your fav-list (eg a station that has ended service / a station beeing not any longer part of the B&O bouquet)
A further minor bug - when selectig "About" >> no information is shown.
Griebel:Same for me with the bug when selecting the About button: black screen.
B&O tech support has been notified about these issues via my dealer yesterday.
"About" button works for me, in a way. It links to a web page on the main site that is not currently active.
how to choose airplay? I believe there was a button to activate - can't find anything...or do I miss something big? (at the moment I connect my phone via cable)
it should be there!
workaround - double press the homebutton - then scroll to the left, and you will see the main AirPlay-icon.
Are you sure your AirPlay-device is online - otherwise it will not show up
Greetings Millemis
Millemissen:double press the homebutton - then scroll to the left
scroll far left - on an iPhone you at first see the star/top audio controls, then scroll again, and that is when you see which is the airplay symbol
Any knowledge of BeoPlayer going full size (natively) for the iPad?
