Essence and Chromecast audio
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sun, Oct 15 2017 8:07 PM
Is it possible to add a £30 Google Chromecast to the Essence mark 1?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Millemissen
Flensborg, Denmark
Posts 14,680
Yes, indeed - just use the line-in connection with an appropriate cable.
The line-in has autosense and the Essence will then switch to that input, when you send something to the Comecast. (Note: if 'occupied' by AirPlay, remember to switch that off in the sending device)
And don't forget to set the Chromecast to Full Dynamic Range in the audio settings of the dongle.
Chris Harrison
Peak District
Posts 381
So if I do that I can make the Essence mark 1 multiroom?
Millemissen
Flensborg, Denmark
Posts 14,680
No, it can make it possible to group the connected Chromecast with other Chromecast devices on your network.
If that is all that you need, all is well.
Chris Harrison
Peak District
Posts 381
Perfect - so I'll just buy more Chromecast and connect them to some speakers!
I have Beolab 3 and the Essence.
An old Beosound 8 which I still love - i'll connect an Essence to that.
And....looking at a Beolab 3500 for the kitchen so I can connect an Essence to that too !
Chris Harrison
Peak District
Posts 381
For some reason I cannot edit the post.
Chromecast to Beosound 8
Chromecast to Beolab 3500
Page 1 of 1 (6 items) | RSS
