hpw do you use the preamp out on beocenter 7700. I hooked it up to amplifier and there was no sound. Thanks.
Hi Billhnj,
From memory, I don't think Beocenter 7700 has pre-out sockets. The options would be to either use the TP2 out sockets with a power amp that has a volume control fitted (under no circumstances should these outputs be connected to an amp without a volume control) or to use the headphone output of the 7700 to an external amp instead.
Please feel free to email me via my sponsor link below if you need any help with cables.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
