claudiu :Please write about your experience with this product, your pictures, explain about the functionality of this product.
Sometimes the only solution eg. if you're running out of local HDMI and/or PUC sockets on your TVs
Functionality - please read ... http://www.atlona.com/pdf/manuals/AT-PRO2HD88M_V2.pdf
In any case, a well desiged layout of the system, a careful installation & setup is required ...
Vienna: claudiu :Please write about your experience with this product, your pictures, explain about the functionality of this product. Sometimes the only solution eg. if you're running out of local HDMI and/or PUC sockets on your TVs Functionality - please read ... http://www.atlona.com/pdf/manuals/AT-PRO2HD88M_V2.pdf In any case, a well desiged layout of the system, a careful installation & setup is required ...
thanks for the link ... big ugly brute of a beast isn't it !
definitely needs to be a cupboard or a basement
BeoNut since '75
elephant: ... big ugly brute of a beast isn't it ! definitely needs to be a cupboard or a basement
... to be mounted in a 19" "server rack" where the other "ugly" parts of the installation for an "intelligent house" eg. switches, firewall, ISP router, hard disk array, patch panels for IP telefone, IT-infrastructure, Home Server for the bus installation of light, shades ect, B&O-ML (NIC) as well as B&O Network-Link,... are installed In an environement full of patch cables and compared to all the other components the Atlona almost looks "sexy" - LOL !
