Samsung UE65MU8005 + beolab 18+19
bomberbob
Posts 7
bomberbob Posted: Tue, Oct 31 2017 10:02 AM
I would like to use my Beolab 18+19 speakers together with my Samsung TV. I tried to connect my Beolab essence to the TV as bluetooth speakers, but the delay is huge and the sound quality is not very good.
Can anyone recommend a solution that can provide:
Minimum amount of delay
Good quality
Possibilty to adjust the sound level with Samsung TV remote
TV triggers Beolab speakers so that they start up when TV is turned on.
It is a Samsung UE65MU8005 and Beolab 18+19 + Beolab Essence mk2
Banker
Posts 5
Banker replied on Tue, Oct 31 2017 11:05 AM
Hi Bob,
How is the Essence connected to the speakers? If this is via Transmitter 1 WiSA, I would recommend using the optical out of your TV and connecting it to the transmitter 1. You'll have to buy the IR receiver for transmitter 1 as well (forgot the exact name but I'm sure other forum members / your B&O dealer do) as the optical out of your samsung TV is probably not volume regulated. You can then adjust the volume with your Beo4 / Beo one remote control.
Best,
Bastiaan
bomberbob
Posts 7
bomberbob replied on Tue, Oct 31 2017 11:45 AM
Hi Bastiaan
Thx for the quick reply.. Right my speakers are connected via ethernet cabel.
Will the Beo one remote work with my samsung tv?
Rgds.
Bo
CB
> You are Here <
Posts 1,762
CB replied on Tue, Oct 31 2017 12:38 PM
Hi and welcome to Beoworld,
did you check the Samsung WAM270 Linkmate ? It may be worth a look... with a Samsung TV!
NB : I don't know about the setting of the delay.
Banker
Posts 5
Banker replied on Tue, Oct 31 2017 1:56 PM
ok, since you have connected the speakers via Ethernet (Powerlink) cables, I think your best option is to use the optical out of your tv, buy a small DAC, which converts the optical signal to RCA. Then connect the RCA cables to your Essence. And buy a IR receiver for the Essence (if you not already have it). In this way, you will be able to control the volume with either the Beo4 or the Essence remote ("wheely"). The speakers will switch on automatically when the TV is switched on as the RCA connections on the essence have a line-sense function.
Best,
Bastiaan
Millemissen
Flensborg, Denmark
Posts 14,680
No delay, then?
Page 1 of 1 (6 items) | RSS
