Essence remote with BV11 configured as BeoRemote One user experience
This post has 0 Replies | 0 Followers
LeMirage
Posts 77
LeMirage Posted: Wed, Nov 1 2017 11:19 AM
Just bought the table version of the essence wheely. For clarification, just the remote not the essence box.
configured it as IR BeoRemote One which is a real easy process. It works great, but not perfect.
we use the BV11 everyday for music via netradio app. With the BV11 in music mode (screen off) you can use the wheely to change stations and adjust the volume (this works smooth)
The lower button can be used to mute and unmute the volume. The top buttun can be used for.......... nothing!!
it would have been PERFECT if the top button would switch on the screen (temporary) on so that you can actually see what you are doing when browsing through the radio station favourites.
Page 1 of 1 (1 items) | RSS
