Connect a BEOSOUND 9000 to a BEOVISION AVANT with AV IN
This post has 4 Replies | 0 Followers
FRDRCJRDN
LYON, FRANCE
Posts 17
Silver Member
FRDRCJRDN Posted: Sun, Nov 5 2017 11:28 AM
Hi everyone,
I have a BEOSOUND 9000 and a BEOVISION AVANT 55 (1st model). My speakers are connected to the TV (Beolab 18 and 19) with RJ45 cables. I would like to have the sound of my BS9000 on my speakers WITHOUT A BEOLINK NL/ML ! I don't need to operate the BS9000 with the TV remote.
I would like to know if this is possible to connect the BS9000 to the TV with the "AV IN" input ? If yes, is this a powerlink cable or another one that I have to use ?
Thanks for your support,
Fred
Millemissen
Flensborg, Denmark
Posts 14,680
You could use something like this:
http://www.ebay.de/itm/Bang-Olufsen-Musiksystem-an-Beovision11-Avant-anschlie%C3%9Fen-ohne-B-O-Converter/271921801031?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
In case - please do report back how that solution is in everyday life.
rxcohen
New York
Posts 201
rxcohen replied on Sun, Nov 5 2017 4:57 PM
I had this setup, but with the BV11-55. I used a SPDIF cable to connect the two digitally, and it worked perfectly. The only thing is that you will not be able to use the radio on the BS9000 (which is not an issue for most), and the only thing you will be able to do with the remote for the BS9000 is turn it on . Steve from SoundHeavenly has the cable here https://www.soundsheavenly.com/beolab-5-beolab-50-and-beolab-90/34--spdif-.html
I do not know what connectors the Avant has, so check first.
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
Millemissen
Flensborg, Denmark
Posts 14,680
The Avant (1st gen) also a digital input port - so no problem there, if it is just about cd playback.
But still it is a halfbaked solution — especially, if you consider buying more NL devices for the setup.
FRDRCJRDN
LYON, FRANCE
Posts 17
Silver Member
Thanks everyone !
I have the beolink NL/ML (that I will sell...) and I would like to connect also to the TV the SONOS CONNECT through the digital SPDIF input. That's why I want to use the AV IN for the BS9000.
I will buy the cable at soundsheavenly (cheaper than eBay).
Many thanks for the tips guys !
If somebody is interested in my Beolink NL/ML...
Fred
Page 1 of 1 (5 items) | RSS
