Beogram 5500 (Type 4950): the turntable hangs down on one side - record grinds on chassis
This post has 3 Replies | 0 Followers
okin
Posts 9
okin Posted: Wed, Nov 8 2017 4:58 PM
Hello. I'm a freshman to B&O.
In my newly acquired Beogram 5500 (Type 4950) the turntable hangs down on the front right side - so the record grinds on the chassis. Below, I have turned out the 3 transport locks completely.
On the left rear, the player seems to be rather firm; not swinging up and down so much (compared to the rest). At the right front it moves very strongly (vertically) and hangs down significantly in the resting position. Also, I have removed the turntable and the underlying cast turntable with the drive belt - I can not see any mistake.
Is there a suspension defect?
What can I do?
Who can help me?
Thank you
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The first thing I would check is that there is nothing  wedged between the sprung chassis and the base plate of the deck.
I have found several old cartridges under there on various B&O type 59xx decks, over the years.
Regards Graham
okin
Posts 9
okin replied on Thu, Nov 9 2017 5:04 PM
Thank you very much. I will check this first.
okin
Posts 9
okin replied on Sat, Nov 11 2017 1:02 PM
Dear Friend,
I have solved the problem.
One of the spings to hold the case did not have enough tension; I screwed in the appropiate srew to put more tension on the spring.
Now the table is in the horizontal.
Thanks.
Okin
Page 1 of 1 (4 items) | RSS
