Beo5 loose ribbon cable
krais
The Netherlands
Posts 136
Silver Member
krais Posted: Mon, Nov 13 2017 8:13 AM
When trying to replace the battery for my Beo5 the ribbon cable came loose from the display housing. Any tips on how to reattach the cable? It seems pretty hard to do without disassembling the display casing but I’m a bit worried that some if the clips that hold the case together might break off.
Thanks.
TWG
Posts 1,672
TWG replied on Mon, Nov 13 2017 10:15 AM
maybe you can try it CAREFULLY with a tweezer?!
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Nov 13 2017 11:46 AM
krais:
Thanks.
It is a pain, but it can be done with a very small screwdriver, the problem is that the locking piece of plastic is hinged on, it will not break off, but can come off. This takes a lot of tries to get on again, but it can be done.
Patience is what is needed here.
/Jacob
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Weebyx:
Early versions of the Beo5 did not even have a locking clamp, it just pushed in!!
Regards Keith....
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Nov 13 2017 12:26 PM
Keith Saunders:
Weebyx:
Much easier :)
I used my Beo6 as reference, I had to remove the ribbon to exchange it :)
/Jacob
Page 1 of 1 (5 items) | RSS
