Bv7-32 mk 3 red line?
This post has 9 Replies | 0 Followers
2012martin
Posts 202
2012martin Posted: Mon, Oct 1 2012 10:12 AM
Hi all. I've just returned from holiday and my bv7-32 mk3 had been disconnected from the mains for two weeks. Upon returning and turning the set back on there is a red stripe/line about 1mm thick running from the top of the screen to the bottom of the screen about 3 inches in from the left.
It looks like a row of dead pixels and it's a red colour? Anybody have any ideas? I thought I have read something similar on here before but can't seem to find it?
Thanks in advance
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Mon, Oct 1 2012 11:30 AM
If your running a Dvi connection,check your Hdmi connection and for the Hand Shacking as well as I have had that. A pixel line down the left had side of the screen!
Hope this helps?
2012martin
Posts 202
It also does this when watching the DVD
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Mon, Oct 1 2012 1:13 PM
I have never had that! On mine....You could try a reset on the tv? or un plug for a few mins, then re try!
Not sure if that would fix/help?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Oct 1 2012 2:28 PM
Is it just a solid line that stays there, or does it flutter around when the images moves?
2012martin
Posts 202
Hi lee it's a solid line that doesnt move. It's about a millimetre thick and about three inches in from the left and its from the top to the bottom. It's like a line of dead pixels.
Cheers
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Oct 1 2012 8:34 PM
The Mk3 panels are pretty reliable. I asked about the line fluttering in case it was the PIM (picture in motion) module playing up - but it seems not.
It seems to me like panel failure, as the chassis would throw up a more general fault than such a precise one.
Either way, I'd recommend an engineer to do a diagnostic check on it....
Sorry to hear of this problem. What a pain !!
Lee
2012martin
Posts 202
Hi lee. This has only just had a new chassis, could it be anything to do with that?
It had a new chassis about three weeks ago and then its been off for two weeks as I've been away
Cheers
2012martin
Posts 202
Do you thnk it's the panel? Or something to do with the new chassis?
Cheers
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Oct 2 2012 4:13 PM
If i remember correctly, you must ALWAYS replace the EEPROM at the exact same time as the chassis. Was this done?
If not, the new EEPROM nukes the chassis, or the new chassis nukes the EEPROM - and you just end up with fault after fault after fault.
I'm stabbing in the dark a little here. I don't claim to be an engineer, but obviously I have a lot of experience in rectifying faults with B&O - always at my own expense, sadly..
Lee
Page 1 of 1 (10 items) | RSS
