Hi All, I have had my phones in storage for a year while travelling around but now have an issue with the set up..
I have the following;
BEOLINE 2 PSTN BASE
2 x BEOCOM 6000 MK1 handset with pyramid chargers only (not the ones with the phone lines integrated
1 x BEOCOM 6000 MK2 handet with pyramid chargers only (not the ones with the phone lines integrated
1 x BEOCOM 2
I can get all handsets connected but the two MK1 handsets are constantly showing "Phone book updating", I have reset them both using DOT7008 on multiple occasions now, i have also reset the base station using DOT70009,
The MK1 handset show the "phone book updating" message even after resseting them (before registering them to the base station again?
FYI when adding the handsets i added both the MK1 handsets first as I beleive the oldest handsets shoudl be registered first?
Everything was working when i packed them away and i took out the batteries from the 6000 handsets.
Any help or guidance appreciated.
Gavin
Welcome to Beoworld!
According to this: https://www.beoworld.org/faq_view.asp?id=74
... the BC6000s Mk1s will not work with the Beoline 2 PSTN. Did you have a different setup before putting them in storage?
This table may help you...
Regards Keith....
Hi Keith, thanks and apologies for the delay in responding, i have all phones working with the Beoline 2 PSTN, that is to say i can make and receive calls, one of them is still showing "phone book updating" despite resetting all phones and base station last week..looks like ill need to keep pursuing this final handset to get the phone book working..
