Normal 0 21 false false false DA X-NONE X-NONE
Hello guys
I am new to the forum, recently having purchased a Beoplay A9
I love it to bits, but the well-known cover-wrinkle problem really annoys me. With a product of such a high quality and price, the fact that the fabric on the speaker is not completely smooth is kind of criminal.
Does anyone have any good tips to how you smooth out the wrinkles with a “home-made” solution?
Yes, I have tried smoothing the surface with the palm of my hand – the wrinkles just move to another place. The sum of wrinkles remains the same.
Yes, I have looked around the forum for an answer to this issue, but my search did not turn up anything, hence the new thread.
No, I have not yet changed to cover. It is as it was when it was delivered from the store.
Cheers and thanks in advance guys!
are the wrinkles to the side?, just slightly push the fabric around the edge in the opposite direction of where the wrinkles are. If it pops off, just struggle to put it back on..
