Beolink NL/ML Converter Reset
beoaus
Posts 177
beoaus Posted: Sat, Nov 25 2017 10:32 AM
Hello,
Is there an way to factory default the BLC? If there is an obvious option I am missing it.
My reason...
I really would like to start again.
I have no sound coming thru from my BS9000 which is joined. The BLC also thinks my Video Master is a BV11 rather than a BV7.
Thanks Beoaus
Fulgore
Posts 28
Fulgore replied on Sat, Nov 25 2017 11:05 AM
Had the last few days (nearly) the same issue with BS5/BM5 connected with the converter.
Restarted the BS5 and the converter. (Electric cable) We don’t have a Video Master.
BR
Fulgore
Posts 28
Fulgore replied on Sat, Nov 25 2017 11:06 AM
BR
beojeff
USA
Posts 2,012
beojeff replied on Sat, Nov 25 2017 11:37 AM
You reset the converter by pressing a straightened paper clip into the small hole and holding it until the LED light flashes red 5 times. Release and press again quickly and release.
beoaus
Posts 177
beoaus replied on Sat, Nov 25 2017 11:12 PM
Thanks Beojeff...
Ok. I now have some meaningfull logs.  It looks to me that the ML audio is being turned off. Would that be a setting I need to change?. Also when I press the Joined CD or Joined Radio on the remote both are displayed on the Beovision Horizon for about 15sec and then a STOPPED message is displayed.
Also odd that the BS9000 (Same rooms as the BV740) has some strange messages in the log. It works in the ML link rooms.
The logs are below.
Nov 26 10:02:28 (none) BLC[1107]: [info]:NL:Connect: from peer: 7980.1860528.27419106@products.bang-olufsen.com, source: {1790.1179011.24094195@products.bang-olufsen.com, CD}, streamingtech_info:FPS://10.1.1.84?ARQBufferSize=200
Nov 26 10:02:28 (none) BLC[1107]: [info]:HDCP library not installed [CpSource.cpp:35]
Nov 26 10:02:28 (none) BLC[1107]: [info]:SetSourceHostname=127.0.0.1 [CpSource.cpp:66]
Nov 26 10:02:28 (none) BLC[1107]: [info]:Stream source listener created
Nov 26 10:02:28 (none) BLC[1107]: [info]:Source graph: ->Connect(FPS://10.1.1.84, <?xml version="1.0" encoding="utf-8"?> <CpCapabilities><ProtectionSchemes><Scheme>NONE</Scheme><Scheme>DECIMATE</Scheme><Scheme>PROPRIETARY</Scheme></ProtectionSchemes></CpCapabilities>)
Nov 26 10:02:28 (none) fpsd: Idea GST.fpsd: Streaming version:1  [fpsd.c:293, 1100.1100]
Nov 26 10:02:28 (none) BLC[1107]: [info]:Source Streaming Version: 0 [SourceGraph.cpp:512]
Nov 26 10:02:28 (none) BLC[1107]: [info]:Connect called for sink: FPS://10.1.1.84 <?xml version="1.0" encoding="utf-8"?> <CpCapabilities><ProtectionSchemes><Scheme>NONE</Scheme><Scheme>DECIMATE</Scheme><Scheme>PROPRIETARY</Scheme></ProtectionSchemes></CpCapabilities> 1 [SourceGraph.cpp:259]
Nov 26 10:02:28 (none) BLC[1107]: [info]:SOURCE: ->SetPlaybackDelayMs(200)
Nov 26 10:02:28 (none) BLC[1107]: [info]:Connected to FPS://10.1.1.84 IP: 10.1.1.84 [AsyncPingClient.cpp:241]
Nov 26 10:02:28 (none) BLC[1107]: [info]:FPSFlowGraph::SourceGraph successfully connected to FPS://10.1.1.84 [SourceGraph.cpp:1691]
Nov 26 10:02:28 (none) BLC[1107]: [info]:==================== Source graph connected: status: OK, NofSinksConnected: 1
Nov 26 10:02:28 (none) BLC[1107]: [info]:Source graph: ->StartSession()
Nov 26 10:02:28 (none) BLC[1107]: [info]:SourceGraph::StartSession [SourceGraph.cpp:552]
Nov 26 10:02:28 (none) BLC[1107]: [info]:SourceGraph::SetPlaybackDelayMs: 200 ms [SourceGraph.cpp:427]
Nov 26 10:02:28 (none) BLC[1107]: [info]:Renderer delays stored but not set, missing source pipeline [SourceGraph.cpp:457]
Nov 26 10:02:28 (none) BLC[1107]: [info]:.. Stream connection status = 1 received
Nov 26 10:02:28 (none) BLC[1107]: [info]:==================== Source graph StartedSession: status: OK, connection state = CONNECTED
Nov 26 10:02:28 (none) BLC[1107]: [info]:Waiting Player to connect  ...
Nov 26 10:02:28 (none) BLC[1107]: [info]:Setting player listener to CD
Nov 26 10:02:28 (none) BLC[1107]: [info]: .. Player connected
Nov 26 10:02:28 (none) BLC[1107]: [info]:FPGA Switch not changed. Input allready set from ML
Nov 26 10:02:28 (none) BLC[1107]: [info]:Adding renderer 7980.1860528.27419106@products.bang-olufsen.com as listener for source CD:1790.1179011.24094195@products.bang-olufsen.com for ML experience
Nov 26 10:02:28 (none) BLC[1107]: [info]:Using distributed experience for status
Nov 26 10:02:28 (none) BLC[1107]: [info]:Notifying BeoNetRemote of new source: CD:1790.1179011.24094195@products.bang-olufsen.com
Nov 26 10:02:28 (none) BLC[1107]: [info]:NL: GetFullStatus
Nov 26 10:02:30 (none) BLC[1107]: [info]:Source selection for ML player CD received with error: Player select error, ML Audiomaster doesn't exist
Nov 26 10:02:30 (none) BLC[1107]: [info]:ML master not found. Retry count 1. Reset H8
Nov 26 10:02:41 (none) BLC[1107]: [info]:H8 communication initialized.
Nov 26 10:02:42 (none) BLC[1107]: [info]:H8 Clock changed to 10:2:42
Nov 26 10:02:42 (none) BLC[1107]: [info]:H8 communication initialized.
Nov 26 10:02:43 (none) BLC[1107]: [info]:Initializing sources visible on ML...
Nov 26 10:02:43 (none) BLC[1107]: [info]:Initialization of sources visible on ML done.
Nov 26 10:02:43 (none) BLC[1107]: [info]:Setting ML sound switch to OFF
Nov 26 10:02:43 (none) BLC[1107]: [info]:Sending available sources to BeoRemote controlling ML
Nov 26 10:02:43 (none) BLC[1107]: [info]:Sending notification: SOURCE_LIST_CHANGED to BeoRemote Clients
Nov 26 10:02:43 (none) BLC[1107]: [info]:H8 configuration done.
Nov 26 10:02:45 (none) BLC[1107]: [info]:H8 Clock changed to 10:2:45
Nov 26 10:02:45 (none) BLC[1107]: [info]:Initializing sources visible on ML...
Nov 26 10:02:45 (none) BLC[1107]: [info]:Initialization of sources visible on ML done.
Nov 26 10:02:45 (none) BLC[1107]: [info]:Setting ML sound switch to OFF
Nov 26 10:02:45 (none) BLC[1107]: [info]:Sending available sources to BeoRemote controlling ML
Nov 26 10:02:45 (none) BLC[1107]: [info]:Sending notification: SOURCE_LIST_CHANGED to BeoRemote Clients
Nov 26 10:02:45 (none) BLC[1107]: [info]:H8 configuration done.
Nov 26 10:02:45 (none) BLC[1107]: [info]:Source selection for ML player CD received with error: Player select error, ML Audiomaster doesn't exist
Nov 26 10:02:45 (none) BLC[1107]: [info]:Clearing player listener for CD
Nov 26 10:02:45 (none) BLC[1107]: [info]:NL:Disconnect: from peer = 7980.1860528.27419106@products.bang-olufsen.com, connectionId = B5A24F04-D234-1100-9700-000000000000
Nov 26 10:02:45 (none) BLC[1107]: [info]:Source graph: ->Disconnect( FPS://10.1.1.84)
Nov 26 10:02:45 (none) fpsd: Idea GST.fpsd: Streaming version:1  [fpsd.c:293, 1100.1100]
Nov 26 10:02:45 (none) BLC[1107]: [info]:Source Streaming Version: 0 [SourceGraph.cpp:512]
Nov 26 10:02:45 (none) BLC[1107]: [info]:SourceGraph::Disconnect: FPS://10.1.1.84 [SourceGraph.cpp:342]
Nov 26 10:02:45 (none) BLC[1107]: [info]:FPSFlowGraph::SourceGraph Disconnecting FPS://10.1.1.84 [SourceGraph.cpp:363]
Nov 26 10:02:45 (none) BLC[1107]: [error]:FPSFlowGraph::SourceGraph::UpdateSinkMutedState, failed to find sink: 10.1.1.84 [SourceGraph.cpp:2244]
Nov 26 10:02:45 (none) BLC[1107]: [info]:FPSFlowGraph::SourceGraph Disconnected FPS://10.1.1.84 [SourceGraph.cpp:1738]
Nov 26 10:02:45 (none) BLC[1107]: [info]:CpSource::RemoveSink (10.1.1.84) [CpSource.cpp:329]
Nov 26 10:02:45 (none) BLC[1107]: [info]:Priority one (Last user win), last user not found, selectableSchemes.size=0 [CpSource.cpp:359]
Nov 26 10:02:45 (none) BLC[1107]: [info]:No scheme found [CpSource.cpp:423]
Nov 26 10:02:45 (none) BLC[1107]: [info]:==================== Source graph Disconnected: Sink: FPS://10.1.1.84, status: OK, Remaining connections = 0
Nov 26 10:02:45 (none) BLC[1107]: [info]:Removing all renders from ML experience having source CD:1790.1179011.24094195@products.bang-olufsen.com
Nov 26 10:02:45 (none) BLC[1107]: [info]:Using distributed experience for status
Nov 26 10:02:45 (none) BLC[1107]: [info]:Clearing current BeoNetRemote active source
Nov 26 10:02:45 (none) BLC[1107]: [info]:Deleting Source graph
Nov 26 10:02:45 (none) BLC[1107]: [info]:Deleting the source [SourceGraph.cpp:1082]
Nov 26 10:02:45 (none) BLC[1107]: [info]:Source graph Destroyed
Nov 26 10:02:45 (none) BLC[1107]: [info]:Distribution connection deleted, number of remaining source connections = 0
Nov 26 10:03:20 (none) BLC[1107]: [info]:NL:Connect: from peer: 7980.1860528.27419106@products.bang-olufsen.com, source: {1790.1179011.24094195@products.bang-olufsen.com, CD}, streamingtech_info:FPS://10.1.1.84?ARQBufferSize=200
Nov 26 10:03:20 (none) BLC[1107]: [info]:HDCP library not installed [CpSource.cpp:35]
Nov 26 10:03:20 (none) BLC[1107]: [info]:SetSourceHostname=127.0.0.1 [CpSource.cpp:66]
Nov 26 10:03:20 (none) BLC[1107]: [info]:Stream source listener created
Nov 26 10:03:20 (none) BLC[1107]: [info]:Source graph: ->Connect(FPS://10.1.1.84, <?xml version="1.0" encoding="utf-8"?> <CpCapabilities><ProtectionSchemes><Scheme>NONE</Scheme><Scheme>DECIMATE</Scheme><Scheme>PROPRIETARY</Scheme></ProtectionSchemes></CpCapabilities>)
Nov 26 10:03:20 (none) fpsd: Idea GST.fpsd: Streaming version:1  [fpsd.c:293, 1100.1100]
Nov 26 10:03:20 (none) BLC[1107]: [info]:Source Streaming Version: 0 [SourceGraph.cpp:512]
Nov 26 10:03:20 (none) BLC[1107]: [info]:Connect called for sink: FPS://10.1.1.84 <?xml version="1.0" encoding="utf-8"?> <CpCapabilities><ProtectionSchemes><Scheme>NONE</Scheme><Scheme>DECIMATE</Scheme><Scheme>PROPRIETARY</Scheme></ProtectionSchemes></CpCapabilities> 1 [SourceGraph.cpp:259]
Nov 26 10:03:20 (none) BLC[1107]: [info]:Connected to FPS://10.1.1.84 IP: 10.1.1.84 [AsyncPingClient.cpp:241]
Nov 26 10:03:20 (none) BLC[1107]: [info]:FPSFlowGraph::SourceGraph successfully connected to FPS://10.1.1.84 [SourceGraph.cpp:1691]
Nov 26 10:03:20 (none) BLC[1107]: [info]:==================== Source graph connected: status: OK, NofSinksConnected: 1
Nov 26 10:03:20 (none) BLC[1107]: [info]:Source graph: ->StartSession()
Nov 26 10:03:20 (none) BLC[1107]: [info]:SourceGraph::StartSession [SourceGraph.cpp:552]
Nov 26 10:03:20 (none) BLC[1107]: [info]:SOURCE: ->SetPlaybackDelayMs(200)
Nov 26 10:03:20 (none) BLC[1107]: [info]:SourceGraph::SetPlaybackDelayMs: 200 ms [SourceGraph.cpp:427]
Nov 26 10:03:20 (none) BLC[1107]: [info]:Renderer delays stored but not set, missing source pipeline [SourceGraph.cpp:457]
Nov 26 10:03:20 (none) BLC[1107]: [info]:.. Stream connection status = 1 received
Nov 26 10:03:20 (none) BLC[1107]: [info]:==================== Source graph StartedSession: status: OK, connection state = CONNECTED
Nov 26 10:03:20 (none) BLC[1107]: [info]:Waiting Player to connect  ...
Nov 26 10:03:20 (none) BLC[1107]: [info]:Setting player listener to CD
Nov 26 10:03:20 (none) BLC[1107]: [info]: .. Player connected
Nov 26 10:03:20 (none) BLC[1107]: [info]:FPGA Switch not changed. Input allready set from ML
Nov 26 10:03:20 (none) BLC[1107]: [info]:Adding renderer 7980.1860528.27419106@products.bang-olufsen.com as listener for source CD:1790.1179011.24094195@products.bang-olufsen.com for ML experience
Nov 26 10:03:20 (none) BLC[1107]: [info]:Using distributed experience for status
Nov 26 10:03:20 (none) BLC[1107]: [info]:Notifying BeoNetRemote of new source: CD:1790.1179011.24094195@products.bang-olufsen.com
Nov 26 10:03:20 (none) BLC[1107]: [info]:NL: GetFullStatus
Nov 26 10:03:22 (none) BLC[1107]: [info]:Source selection for ML player CD received with error: Player select error, ML Audiomaster doesn't exist
Nov 26 10:03:22 (none) BLC[1107]: [info]:ML master not found. Retry count 1. Reset H8
Nov 26 10:03:33 (none) BLC[1107]: [info]:H8 communication initialized.
Nov 26 10:03:33 (none) BLC[1107]: [info]:H8 Clock changed to 10:3:33
Nov 26 10:03:34 (none) BLC[1107]: [info]:H8 communication initialized.
Nov 26 10:03:34 (none) BLC[1107]: [info]:Initializing sources visible on ML...
Nov 26 10:03:34 (none) BLC[1107]: [info]:Initialization of sources visible on ML done.
Nov 26 10:03:34 (none) BLC[1107]: [info]:Setting ML sound switch to OFF
Nov 26 10:03:34 (none) BLC[1107]: [info]:Sending available sources to BeoRemote controlling ML
Nov 26 10:03:34 (none) BLC[1107]: [info]:Sending notification: SOURCE_LIST_CHANGED to BeoRemote Clients
Nov 26 10:03:34 (none) BLC[1107]: [info]:H8 configuration done.
Nov 26 10:03:36 (none) BLC[1107]: [info]:H8 Clock changed to 10:3:36
Nov 26 10:03:36 (none) BLC[1107]: [info]:Initializing sources visible on ML...
Nov 26 10:03:36 (none) BLC[1107]: [info]:Initialization of sources visible on ML done.
Nov 26 10:03:37 (none) BLC[1107]: [info]:Setting ML sound switch to OFF
Nov 26 10:03:37 (none) BLC[1107]: [info]:Sending available sources to BeoRemote controlling ML
Nov 26 10:03:37 (none) BLC[1107]: [info]:Sending notification: SOURCE_LIST_CHANGED to BeoRemote Clients
Nov 26 10:03:37 (none) BLC[1107]: [info]:H8 configuration done.
Nov 26 10:03:37 (none) BLC[1107]: [info]:Source selection for ML player CD received with error: Player select error, ML Audiomaster doesn't exist
Nov 26 10:03:37 (none) BLC[1107]: [info]:Clearing player listener for CD
Nov 26 10:03:37 (none) BLC[1107]: [info]:NL:Disconnect: from peer = 7980.1860528.27419106@products.bang-olufsen.com, connectionId = D479ABAC-D234-1100-B000-000000000000
Nov 26 10:03:37 (none) BLC[1107]: [info]:Source graph: ->Disconnect( FPS://10.1.1.84)
Nov 26 10:03:37 (none) fpsd: Idea GST.fpsd: Streaming version:1  [fpsd.c:293, 1100.1100]
Nov 26 10:03:37 (none) BLC[1107]: [info]:Source Streaming Version: 0 [SourceGraph.cpp:512]
Nov 26 10:03:37 (none) BLC[1107]: [info]:SourceGraph::Disconnect: FPS://10.1.1.84 [SourceGraph.cpp:342]
Nov 26 10:03:37 (none) BLC[1107]: [info]:FPSFlowGraph::SourceGraph Disconnecting FPS://10.1.1.84 [SourceGraph.cpp:363]
Nov 26 10:03:37 (none) BLC[1107]: [error]:FPSFlowGraph::SourceGraph::UpdateSinkMutedState, failed to find sink: 10.1.1.84 [SourceGraph.cpp:2244]
Nov 26 10:03:37 (none) BLC[1107]: [info]:FPSFlowGraph::SourceGraph Disconnected FPS://10.1.1.84 [SourceGraph.cpp:1738]
Nov 26 10:03:37 (none) BLC[1107]: [info]:CpSource::RemoveSink (10.1.1.84) [CpSource.cpp:329]
Nov 26 10:03:37 (none) BLC[1107]: [info]:Priority one (Last user win), last user not found, selectableSchemes.size=0 [CpSource.cpp:359]
Nov 26 10:03:37 (none) BLC[1107]: [info]:No scheme found [CpSource.cpp:423]
Nov 26 10:03:37 (none) BLC[1107]: [info]:==================== Source graph Disconnected: Sink: FPS://10.1.1.84, status: OK, Remaining connections = 0
Nov 26 10:03:37 (none) BLC[1107]: [info]:Removing all renders from ML experience having source CD:1790.1179011.24094195@products.bang-olufsen.com
Nov 26 10:03:37 (none) BLC[1107]: [info]:Using distributed experience for status
Nov 26 10:03:37 (none) BLC[1107]: [info]:Clearing current BeoNetRemote active source
Nov 26 10:03:37 (none) BLC[1107]: [info]:Deleting Source graph
Nov 26 10:03:37 (none) BLC[1107]: [info]:Deleting the source [SourceGraph.cpp:1082]
Nov 26 10:03:37 (none) BLC[1107]: [info]:Source graph Destroyed
Nov 26 10:03:37 (none) BLC[1107]: [info]:Distribution connection deleted, number of remaining source connections = 0
Nov 26 10:04:13 (none) BLC[1107]: [info]:Looking for a new software...
Nov 26 10:04:13 (none) BLC[1107]: [info]:Checking for software updates...
Nov 26 10:04:14 (none) BLC[1107]: [info]:Update info isAvailable: 0
Nov 26 10:04:14 (none) BLC[1107]: [info]:Update url:
Nov 26 10:04:14 (none) BLC[1107]: [info]:Beoportal sw ver:
Nov 26 10:04:14 (none) BLC[1107]: [info]:No new updates available.
Nov 26 10:04:14 (none) BLC[1107]: [info]:No software updates available
Nov 26 10:05:04 (none) BLC[1107]: [info]:HwTest event server started
Nov 26 10:05:24 (none) BLC[1107]: [info]:Looking for a new software...
Nov 26 10:05:24 (none) BLC[1107]: [info]:Checking for software updates...
Nov 26 10:05:25 (none) BLC[1107]: [info]:Update info isAvailable: 0
Nov 26 10:05:25 (none) BLC[1107]: [info]:Update url:
Nov 26 10:05:25 (none) BLC[1107]: [info]:Beoportal sw ver:
Nov 26 10:05:25 (none) BLC[1107]: [info]:No new updates available.
Nov 26 10:05:25 (none) BLC[1107]: [info]:No software updates available
beoaus
Posts 177
beoaus replied on Sun, Nov 26 2017 9:06 AM
Well after a day and a half of re reading manuals, resets and configuration changes by process of elimination I worked something out. If on the Horizon you select an audio source from the Video Master, like say DTV, then switch to joined CD or joined radio you get sound and control from/to the BS9000. Its seems otherwise, the ML Audio Master is never found.
The logs also show connection to the BS9000 as well...
Perhaps this makes sense to others.
Beoaus.
Page 1 of 1 (6 items) | RSS
