Hello folks, I have a rather lovely Beovision Avant 32 DVD with Beo 4 Remote that I enjoy and use daily. A steal from eBay at £31 purchased from original owner!
It's an 8443 model with 7.20 Software. I'm looking to find out if there is anyway to date the unit from the serial number and also if there is any info about software installed. I've seen some Avants with 10.4 etc...
And finally... my DVD has developed a fault and struggles to read discs now. Lense has been thoroughly cleaned. Sled mechanism moves but might be getting stick. Any ideas of fix info would be amazing.
Cheers everyone
Charlie
Welcome to Beoworld.
Start off by searching the archived forum (top right tab). You will find many similar Avant /DVD problems. Google Translate will also help for the non-English threads.
Graham
Thanks Graham
