Beomaster 1200 Replaced capacitors now Resistor is Smoking
This post has 10 Replies | 0 Followers
greenwolf
Posts 7
greenwolf Posted: Mon, Oct 1 2012 8:15 PM
Hi Beo Fans,
Got a capacitor replacement kit for Beomaster 1200. Spent weekend installing all electrolytic caps and removing old ones.
When powering up resistor no. 421 started smoking (0.15ohm/1 watt). Transformer and rectifier very hot. Can anyone offer me help on why?
This is on the power supply board, you use voltage across resistor 421 to set trimmer pot, instead of 7.5mV I got reading of 390 and up before smoking resistor stopped play.
Much appreciated.
Puncher
Durham
Posts 11,729
Puncher replied on Mon, Oct 1 2012 8:58 PM
Was the Beomaster working before the re-cap??
If so, I'm not familiar with the particular Beomaster and so, I can only suggest looking for solder bridges / short circuits, incorrect capacitor polarity or incorrect capacitor values fitted.
Ban boring signatures!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Oct 1 2012 9:41 PM
That's one of the output stage dropper resistors.
The heat and smoke comes from a too high current draw.
Make sure, you have correct trimmers in correct positions, particularly the
two 470 ohms trimmers on the amplifier board and that they are both soldered in correctly.
If that's all fine, you probably have one or two shorted output stage transistors or some
other short in that channel output stage.
greenwolf
Posts 7
Thanks Martin, just to be sure on the transistors please see my photo in attachedpdf file. Incidentally I double checked the orientation of the capacitors and don't see any problems there, if you spot one please drop me a line. Again thanks for the input.
Dillen
Posts 13,191
Dillen replied on Tue, Oct 2 2012 4:19 PM
Looks fine.
The output stage transistors are fitted to the bottom plate of the Beomaster, using it as a cooling fin.
greenwolf
Posts 7
OK, that's a rellief so you are referring to these (as in the new pdf)
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Check the output transistors if they are faulty.
Make sure that you use the right trimmer to adjust the idle current. (R421)
greenwolf
Posts 7
Thanks for the advice beobuddy. At this stage I am afraid to touch the trimmer pots before I sort out the smoking resistor. Just out of interest how do I test the transistors in question?
greenwolf
Posts 7
Puncher sorry for not thanking you earlier after your post did check for polarity on caps and shorts- nothing untoward it seems. Amp was working before the recap job but right speaker channel not as loud as left speaker, also on power up had a thump, hence the recap.
Beobuddy
Posts 3,972
Normally for jobs like these a Variac is used. With a variac you can vary the main voltage between 0 and 250V.
You could try using a 220V light bulb in series with the amplifier. Then you can set the trimmer to the lowest possible measured value.
But better, measure the value of the old trimmer and set the new one to the same value.
greenwolf
Posts 7
Hi Martin,
Checked the output stage transmitters and got following readings:
Output Transistor
1
Output Transistor
2
Output Transistor
3
Output Transistor
4
Red Multimeter Lead Black Multimeter Lead
260 329 224 241 b e
484 506 420 242 b c
259 329 224 241 e b
447 446 378 overload e c
637 1267 434 overload c e
749 879 651 243 c b
Am I right in saying that transistor 4 is good and the others are all bad? I used multimeter on "bleep" diode test, note that I did not take the transistors out of circuit for the test.
Thanks man
Page 1 of 1 (11 items) | RSS
