So have a chance to get a 1700 with an "excellent" MMC20EN..currently have a RX2 with MMC3 with an intermittent hum...which is the "better" table?
thanks!
I'd say the one that's not humming is the better table! But that will be the deciding factor as Cleviebabie says, both are excellent.
Jeff
Hi - have you checked the cartridge for hum?
I have a 6002 that suddenly developed a loud humm - as if it wasn't grounded - this was after I moved it and got bumped - I looked inside it but everything looks ok so am assuming it's the cartridge.
