BeoSound Core (unpacking)
This post has 34 Replies | 0 Followers
elephant
AU
Posts 8,219
elephant Posted: Sat, Dec 2 2017 7:03 AM
For what it’s worth ... not the most exciting product !
BeoNut since '75
elephant
AU
Posts 8,219
Not a pristine unpack as the store (Ben) and I had already had a go ...
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
elephant:
BeoNut since '75
Ed. Looks good.
What are you gonna use it for ?
koning
holland
Posts 4,220
koning replied on Sat, Dec 2 2017 8:19 AM
It weighs almost nothing...
Aussie Michael
Melbourne, AU
Posts 3,730
Even better 👍🏻
elephant
AU
Posts 8,219
Unwrapped ...
BeoNut since '75
elephant
AU
Posts 8,219
Snap out ...
Snap in ...
BeoNut since '75
elephant
AU
Posts 8,219
So there’s the unpacking, unwrapping, and snapping in ...
What did NOT work was the power on, the flashing light, and the appearance on the BlueTooth list ...
So I think I have a DOA
And yes it’s light
So light that I would almost believe that there is nothing inside !
Back to the shop tomorrow [:\'(]
BeoNut since '75
elephant
AU
Posts 8,219
Aussie Michael:
Ed. Looks good.
To replace the Essence which will go to another room.
What I hope to gain is superior sound by using an all optical path for all my streaming sources
BeoNut since '75
elephant
AU
Posts 8,219
Into shop
Shop checks things, no go, knowing other AU adapter plugs have had issues they deconstruct the plug, give it a wiggle, force it back, reconnect .... and voila a white light.
So Home we did trot, did a re-snap-out, re-snap-in, white light, yayyy
BlueTooth search, found BS Core xxxx, Connect, use B&O App, add product, select found BS Core xxxx, rename it, add WiFi and its password, allow google cast, all good
Software auto-updates, reboots, speakers go pop-pop we’re here Big Smile
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
is the sound better?  Is this for the 20s?
Aussie Michael
Melbourne, AU
Posts 3,730
ooh: next question please
what does the CORE do that the essence doesn't?  Or is it just the better optical?
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sun, Dec 3 2017 7:59 AM
Thanks for sharing.
Next one your new telly ?
elephant
AU
Posts 8,219
BeoGreg:
Thanks for sharing.
Surely !
I have no other acquisition plans ...
The open question is “BV or not BV”
Although this afternoon while I was in the queue (Surprise yes a queue in B&O store ! And that include a group of showing a lot of interest in the Shape) I was able to educate myself on the Eclipse’s Deezer App ... and at the same realising how important VOICE has to be for our B&O future (I had not realised how much voice commands and search terms I use on a daily basis)
Anyway the Eclipse 55” is still in the hunt Smile
BeoNut since '75
elephant
AU
Posts 8,219
Aussie Michael:
Step by step ... the optical cabling is next !
BeoNut since '75
elephant
AU
Posts 8,219
Aussie Michael:
TBH I don’t know ... I will be relocating the Essence to drive the 6000s in a “new” room.
I prefer the Core as it less obtrusive.
And it has been pumping music for some 3 hours without a glitch.
I am assuming it has more powerful chips given how technology advances.
I have as yet not decide where the wheelie goes - the Core supports pairing - however the best room might be to follow its Essence.
I don’t think the IR eye has support in the Core so Beo remote control is a loss.
Also right now I appear to have a BLC NL/ML issue - no doubt caused by me being super cautious with a mass power down on Friday on account of the (non-eventusting) super-storm warnings.
BeoNut since '75
elephant
AU
Posts 8,219
Aussie Michael:
I made a long post - let’s hope it’s released from mod camp soon.
In short only for the optical.
BeoNut since '75
Duels
England
Posts 2,553
Duels replied on Sun, Dec 3 2017 9:36 AM
Good stuff Mr Elephant. I’ll be interested to hear how you get on with the core as I’m thinking about one myself.
dueno
Posts 101
dueno replied on Sun, Dec 3 2017 11:37 AM
How do you connect a beosound core to two beolab 3. The beosound core has only one powerlink plug???
tph
Denmark
Posts 161
tph replied on Sun, Dec 3 2017 12:12 PM
dueno:
You can use a Power Link splitter, like this one: https://www.soundsheavenly.com/bang-olufsen/27-rj45-powerlink-compatible-splitter-new-powerlink-to-two-8-pin-din-powerlink-compatible-sockets.html
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
elephant
AU
Posts 8,219
dueno:
I use the splitter cable in various situations.
However the Core’s single output (in 3 flavours, optical, dolls, and pl) is not a problem as BL20s support daisy chaining.
BeoNut since '75
BillC
Posts 121
BillC replied on Mon, Dec 4 2017 9:21 PM
Hi elephant
Thanks for the post and your unpacking.
Hope you are enjoying your new toy. I’ve hooked up my Core to the BeoLab 3s and it sounds great. Have you tried powering the setup down with the speakers yet? Everytime I do so I hear a big pop from the BeoLab 3s if I power down Core first or all three together. Just interested on hearing how people get away from this pop without needing to stagger the BeoLab 3s first then Core Big Smile
Btw on my Core the Chromecast is rock solid but airplay gets quick a few drop outs.
elephant
AU
Posts 8,219
elephant replied on Mon, Dec 4 2017 10:25 PM
I am used to the pop-pop on the two BL20s - I wouldn’t say its any louder with the Core.
So far I have only used the B&O App to invoke Deezer HiFi ... and maybe one iTunes file via DLNA & PLEX.
I’ll watch out for any Airplay issues !
BeoNut since '75
Duels
England
Posts 2,553
Duels replied on Mon, Dec 4 2017 10:44 PM
BillC:
Hi elephant
How are you turning them off separately?
elephant
AU
Posts 8,219
elephant replied on Tue, Dec 5 2017 10:35 PM
Here’s a surprise !
Apologise for the lack of depth of field - I’ll explain below ...
Slowly fully integrating the Core
Paired it with my 🍎 watch and the Core’s light turned blue 💡
And the B&O App shows “Playing from Bluetooth” and the track name & artist meta data but no albums art
Surprisingly there seems a heavier than usual bass presence ... need more tests !
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Tue, Dec 5 2017 10:47 PM
However I can't get the BLC NL/ML to integrate ... It's almost as if installing the Core has crippled something.
At first I thought it was my mass power down for the severe storm warning but today I find I can interrogate the BLC's strings ... Except for the detailed settings ! where the busy dial goes round and round Andy round and ....... Any hints / tips / suggestions ?
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
Restart everything on the NL.
elephant
AU
Posts 8,219
Millemissen:
Hmmm
I might just kick the BLC and see what happens
BeoNut since '75
elephant
AU
Posts 8,219
Millemissen:
Well done
It worked
Thank you
BeoNut since '75
koning
holland
Posts 4,220
koning replied on Wed, Dec 6 2017 8:38 PM
Deleted
koning
holland
Posts 4,220
I send it back...sound is not good en the app is not 100%
Duels
England
Posts 2,553
Duels replied on Wed, Dec 6 2017 8:55 PM
koning:
What was it connected to and how were you using it (Deezer, Spotify, via chrome cast etc)?
koning
holland
Posts 4,220
koning replied on Wed, Dec 6 2017 9:19 PM
Music from the nas via dlna.
Connected to powerlink
laseralex
Posts 240
laseralex replied on Wed, Dec 6 2017 10:33 PM
elephant:
Compared to everything else from B&O the Wheelie remotes are relatively affordable - you could certainly get another.  (I have three for my bedroom Essence: once by the bed, one by the door, and one in the bathroom where I have additional speakers.)
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
BillC
Posts 121
BillC replied on Thu, Dec 7 2017 12:00 AM
Hi Duels,
Apologies for the late reply.
No I’m currently turning off all three together as I put all three on one power board and just switch off the power board.
Oh well pop pop it is Big Smile
Page 1 of 1 (35 items) | RSS
