good morning, with old Beo4 /w GO there was the "A.opt" function to change the option setting for e.g. a Beosound 3000. I wanted to change the setting of my Beosound 3000 with a new Beo4 (/w nav button), but in the long list under "LIST AV? " there is no "A.opt"....
so how do I change the setting of a Beosound 3000 from e.g. option 0 to option 1 with a new Beo4? thanks!
Rene
It should be the same as the old Beo4. Press the POWER button and LIST together. Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show A.OPT.
ah, got it :-). I was in the "ADD" menu....thanks and apologies!
No problem - glad it worked!
