Hi there – pressing mute on several different remotes and at the Beomaster itself causes only the right channel to mute – any suggestions please?
Many thanks
Sounds like a Mute Relay problem. If you search the forum you will find other posts on the subject as it affects other B&O systems also.
Thanks Guy
Guy: Sounds like a Mute Relay problem.
That, but also check that you actually have connected both L and R speaker to the Speaker 1 outputs (that are mutable) and not Speaker 2 outputs.
