Internet Radio/iTunes on ML bus
This post has 1 Reply | 0 Followers
Raeven
Posts 61
Raeven Posted: Mon, Dec 4 2017 6:54 AM
Hello friends I need your help/opinion:
At the moment I have my itunes connected to the ML bus via my Beosound 9000. This by connecting a Apple airport express to the AUX of the Beosound 9000. In this way I can access in every room the itunes by pressing the A-tape on the remote.
Is there an other way how to do this? I would like to connect in some or other way directly to the ML bus, but still in such a way that I can switch it on with the B&O remote.
Your help is appreciated!
Joop
elephant
AU
Posts 8,219
Historically there was the BeoPort approach — however this is now so obsolete that I think your current approach is safer financially.
The latest approach would be the BeoSound Core which is twice the price the BeoPort was, is not ML based, would require you to build a DLNA compatible server for your iTunes library, and you would still have to use AUX input sand A.TAPE.
BeoNut since '75
Page 1 of 1 (2 items) | RSS
