Beoplay V1 - Start Timer
This post has 9 Replies | 1 Follower
Vintage_B&O
Germany
Posts 303
Vintage_B&O Posted: Sun, Dec 10 2017 10:52 PM
I use a nice Beoplay V1 in my bedroom. Is there any possibility to start the tv with a timer? I would like to use it as alamclock to start up with radio. Is this possible?
Mirco
Millemissen
Flensborg, Denmark
Posts 14,680
As far as I remember the only way would be to use a BeoTime.
The tv itself has no timer-on function.
.....oh wait, you could also integrate (!) an Essence/Core with it and use that to wake you up with the Tunein radio function there.
This way it would turn on the V1.
Vintage_B&O
Germany
Posts 303
I can integrate a essence or a core? Anybody now, whats the price for a core? Maybe this is a option to use the speaker. How does the TV start? Wake on lan?
Mirco
Millemissen
Flensborg, Denmark
Posts 14,680
This may help:
https://bogo.custhelp.com/ci/fattach/get/1304261/0/filename/Multiroom+-+october+2017+-+PDF+handout.pdf
Look at page 4
The timer/s will have to be made in the Bang Olufsen app.
When integrated, the Essence/Core will use the speakers of the V1 as its own speakers,
and this way turn on the tv at the programmed time/source.
Of course the V1 must be configured for this - including WOL.
Vintage_B&O
Germany
Posts 303
Thank you!
Ich will try this and ask my dealer. Maybe this is a solution.
Seanie_230
UK
Posts 2,278
I achieved this with my BLGW
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Vintage_B&O
Germany
Posts 303
Can you tell me how you have done this? I am thinking of buying one to connect my B&O Equipment with my smart home "DIGITALSTROM"
Millemissen
Flensborg, Denmark
Posts 14,680
If that is what you aim for, it definitely is the way to go.
I did not suggest it because not that many B&O owner want/need a BLGW.
Vintage_B&O
Germany
Posts 303
I am looking for a BLGW to test it, but the retail price is to high for just one test.
Maybe sometimes I found one on eBay :-)
Seanie_230
UK
Posts 2,278
Hello
Basically I created a macro that is timed.
The macro fires HDMI1 to on at 0630.
It then presses backup after a few seconds
Then a Chanel number after another few seconds.
Reason for backup is why SkyQ comes on it’s at the TV guide and for numbers to be typed it must be at normal viewing.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (10 items) | RSS
