Spotify can only be passed to other licensed Spotify products. Since the NL/ML converter isn't licensed for Spotify, you cannot push Spotify to it.
You can go in the other direction - if you have a Spotify streamer (e.g. Chromecast) connected to the AUX input of your ML audio / video master, this can be distributed into your NL network by the NL/ML converter since it is just "audio" - no one knows if it is coming from Spotify or not.
Stan
Hi all
I assume that the delay box is also discontinued?
Also, I remember there was a thread some time ago explaining that there was an echo when playing the same source on both NL and ML at the same time, but I cannot find that thread.
Can someone please shortly explain the downside(s) or limitation when integrating NL with ML?
Before I go out and buy a NL/ML converter and a delay box.
Thanks.
Leo
I have one for sale
beolion: Also, I remember there was a thread some time ago explaining that there was an echo when playing the same source on both NL and ML at the same time, but I cannot find that thread.
Is it this one, that you mean?
http://archivedforum2.beoworld.org/forums/p/6073/135722.aspx#135722
Millemissen: Is it this one, that you mean? http://archivedforum2.beoworld.org/forums/p/6073/135722.aspx#135722 MM
Yes, thanks a lot.
