Hello
I have a beosound 9000 mkIII. Now it says cleaning required, so i need to open the glas door and clean it. But heres the problem. When im pressing the button to open the glas door it says locked on the display.
Anyone know how to fix this?
abbe1337: Hello I have a beosound 9000 mkIII. Now it says cleaning required, so i need to open the glas door and clean it. But heres the problem. When im pressing the button to open the glas door it says locked on the display. Anyone know how to fix this?
SHIFT 9 0 3 6 9 on a beolink 1000 remote (maybe Beo4 with SHIFT added to list)
This locks and unlocks the glassdoor
/Jacob
Hello, i have a Beo4, Can you tell me exactly what to do?
Fügen Sie "Shift" in der Listenfunktion mit Beo 4 hinzu
Hello,
i found the shift button, but When i press it nothing kappens?
Nothing happena, it still says ”lock”
