E8 with Samsung Note 8
This post has 4 Replies | 3 Followers
jhbm
Posts 1
jhbm Posted: Thu, Dec 14 2017 3:09 AM
I tried to set up E8 with my Note8 today and still not able to use it. after i followed the manual, called tech support. Two different tech people tried everything and i was told that E8 is not compatible with Note8.
phone was paired with E8 but not communicating or connected. They said I have to wait for software updates which might happen next week or so. Is there other people having same issue or anybody knows how to figure this out.
Harrytran91
Posts 5
I got the same issue when i first paired it with my S8. the e8 was paired but not "connected" so couldn't play music/receive calls.
You will need to pair it with the beoplay app, follow the instructions. To be honest i got lucky, not sure what i did. After pairing the e8 using the app, i went to the phone's bluetooth setting, chose the cog next to the paired e8, which took me to a different setting page for the paired e8. there were 2 options: "used for call" and "used for media". I turned both options on and it started working wonderfully.
djcho1456
Posts 1
djcho1456 replied on Wed, Dec 27 2017 3:36 AM
Anyone knows when this problems solved? Samsung Galaxy7 isn't working neither..
Buster5
Posts 2
Buster5 replied on Sat, Jan 20 2018 8:36 AM
Hi
New user. I cant connect my e8's to my note 8. I have a blinking white light on right earbud. Any idea
Ulrike
Germany
Posts 174
Ulrike replied on Sat, Jan 20 2018 10:34 AM
You may try:
Uninstall the Beoplay app from your phone.
Go to your phone's bluetooth settings and try pairing the E8 just via Bluetooth. Try several times and if it works:
Go to your Note 8 sound settings and modify the sound there.
Hope this helps, good luck!
Page 1 of 1 (5 items) | RSS
