So Deezer HiFi subscription is going to be/ is already on Eclipse. To get the absolute best out of this with B&O high end speakers (BL5, BL50 or BL90), how do you connect from Eclipse to the speakers? With only Powerlink output from Eclipse, isn't this non-optimal compared to say a digital connection? Or does this not matter?
If it does matter, and if Eclipse cannot support a digital output to front speakers, what is the best way to get Deezer HiFi to your speakers?
BV6-26, BV7-40, BL7.4, BL3, BL5, BS9000, BC1, ES1, Beo4, BeoPort
Beer_Baron: With only Powerlink output from Eclipse, isn't this non-optimal compared to say a digital connection? Or does this not matter?
I'm not an expert on the Eclipse, but using WIsa to BL50/90 should give a pure digital signal transfer and thus avvoid one DA/AD step in the signal flow, or? (Our BL5 will only use digital input when receiving the CD-Source sentence via PL from BS9000 or similar, otherwise the BL5s will have to do an extra AD step on the analogue PL signal. Thus - analogue transfer of the sound will require one extra DA/AD step from the source to the speakers).
BV Eclipse 65, BV5, BS Core, BL5, BL8000, BS9000, Beolit 12, A1, A2, P2, H8, H9i, H7, E8
