Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
I have both the BeoRemote One and Beo4. My wife and I prefer the Beo4 for our use case, multiple sources with a one touch access, and we can feel around the remote without looking at it. Just our preference, however we both agree the BeoRemote One looks amazing in comparison to the Beo4.
I totally agree. The BEO4 is far more intuitive than the BR One, especially if you have a B&O audio system ex bs3000 besides ex Avant 55.. The BR One drives me crazy with all the touches needed to switch comandos between audio and video system. On the BEO4, it you press tv, the tv lights on. If you press cd, the cd starts.Now, try that on a BR One
GUILLOT:On the BEO4, it you press tv, the tv lights on. If you press cd, the cd starts.Now, try that on a BR One
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
set the 3 or 4(depending on remote) custom buttons to do what you want... CD, TV, ATV, etc.
Being a big fan of the Beo4, I disliked the BeoRemote One at first. However, it eventually became my remote of choice. My biggest problem with the BeoRemote One is that it lacks the tactility of the Beo4. It's not as easy to use in the dark if you need to access the numeric or even the "back" button. If you only have an ML system WITH NO BLGW, then the Beo4 is good for you. However, once you start expanding to NL and/or use a BLGW, then the BeoRemote One is far better. You can edit the source buttons and rename them and you can also edit and rename the LIGHT and CONTROL functions. I would add that the BeoRemote BT has a HUGE benefit over the non-BT version. You can easily upgrade the software with any B&O BT devices. I've already seen more CONTROL functions added with the BT version. Also, the LIST button is in a more ergonomic positioned with the BT remote.
