Hi all,
I recently bought a BeoSystem 2500 and there's a tiny problem where the glass doors are slightly misaligned at the top (see photo) - it's not a huge problem and everything works fine, was just wondering if anybody knew how to fix it?
Not 100% sure if the Vintage section is the right place to post this, but the BeoSystem is 24 years old so I'm guessing it is!
Thanks !
Hi Jon,
Have a look here: http://archivedforum2.beoworld.org/forums/t/4707.aspx
Good luck!
Guy: Hi Jon, Have a look here: http://archivedforum2.beoworld.org/forums/t/4707.aspx Good luck!
All done! Thanks again for the link :)
