Essence jumps to next radio station
This post has 11 Replies | 1 Follower
jans
Belgium
Posts 394
jans Posted: Mon, Dec 18 2017 8:15 PM
since a couple of days my Essence MkII is behaving weirdly.
We usually listen to TuneIn, and most often to the second favorite station in our list of favourites. However, after streaming this radio station for a while, the Essence all of a sudden jumps to the next radio station, and starts playing the 3th station in my list of favourites.
Strangely enough, from then onwards the Essence doesn't jump to the next station, but continues to play the same station for hours.
Does anyone experience the same behaviour? Any suggestions how to solve it? I already logged out from tune-in both at product and at Tune-in level, and also restarted the Essence. Nothing seems to help.
I recently added an A6 to my set-up, but I think I already noticed this behaviour prior to buying the A6.
All suggestions and ideas are more than welcome!
elephant
AU
Posts 8,219
elephant replied on Mon, Dec 18 2017 9:21 PM
It behaves that way with a streaming playlist when there is a bandwidth glitch ... perhaps that’s your issue ? The first station has lower throughout than the third one - which would be why it then stays locked on ?
BeoNut since '75
jans
Belgium
Posts 394
jans replied on Mon, Dec 18 2017 9:28 PM
Hi Elephant
Thanks for your feedback. Any idea how I can check your suggestion? The Essence has a wired connection, so I assumed that bandwidth is not the issue. Or am I misunderstanding your comment?
Jan
elephant
AU
Posts 8,219
elephant replied on Tue, Dec 19 2017 3:31 AM
Hi Jan
I would run a ping test for say 10 minutes to each destination and see how many drop outs and retries there were.
Tracert is also useful in discovering how many hops there are between you and the two sources.
BeoNut since '75
ngnear
Posts 245
ngnear replied on Tue, Dec 19 2017 5:11 AM
I have also had the same problem with my M5. The first „station“ stops playing and the second starts up.
The station in question has its own app, and when I tried to access the live stream through that it also failed. So I guess in my case it is due to the general unavailability of a live stream from the radio station. I think TuneIn just aggregates the streams and doesn’t actually produce them itself.
Tim
elephant
AU
Posts 8,219
elephant replied on Tue, Dec 19 2017 5:57 AM
Tim, I think you are on the money there.
I’ll try to post some sample diagnostics shortly so others can test from their homes.
BeoNut since '75
jans
Belgium
Posts 394
jans replied on Tue, Dec 19 2017 6:30 AM
elephant:
I’ll try to post some sample diagnostics shortly so others can test from their homes. BeoNut since '75
That would be very helpful for me!
CB
> You are Here <
Posts 1,762
CB replied on Tue, Dec 19 2017 7:36 AM
I observed the same behaviour on my BS35 when a radio signal is too weak, or stopped, or if it takes to much time to "start".
--> it may not be an issue with your Essence but with this specific radio stream (as you already imagined)
To check this hypothesis, try to change the order of your favorites: if the second station is still skipped, there’s a problem!
Another issue may come from the band choice made by the app.
Beocare told me the app automatically choose the highest flow. If it’s too weak, same problem. I don’t know if the app changes to a lower speed then?
A method may be to go to the radio website (not via the dedicated app) and to check if several flows are proposed (with the complete internet address). If yes, you can add a custom radio station in your profile on Tunein website.
The B&O app is now able to play Tunein’s custom radio.
elephant
AU
Posts 8,219
elephant replied on Tue, Dec 19 2017 8:17 AM
Here is an example of a ping ... to radio.paradise ... note that while there were no errors (such as information packets being lost) there was a variation in the time taken to return the signal
ping stream-dc1.radioparadise.com
PING stream-dc1.radioparadise.com (174.36.251.136): 56 data bytes
64 bytes from 174.36.251.136: icmp_seq=0 ttl=50 time=241.804 ms
64 bytes from 174.36.251.136: icmp_seq=1 ttl=50 time=406.841 ms
64 bytes from 174.36.251.136: icmp_seq=2 ttl=50 time=325.200 ms
64 bytes from 174.36.251.136: icmp_seq=3 ttl=50 time=550.187 ms
64 bytes from 174.36.251.136: icmp_seq=4 ttl=50 time=469.462 ms
64 bytes from 174.36.251.136: icmp_seq=5 ttl=50 time=244.939 ms
64 bytes from 174.36.251.136: icmp_seq=6 ttl=50 time=306.564 ms
64 bytes from 174.36.251.136: icmp_seq=7 ttl=50 time=239.312 ms
^C
--- stream-dc1.radioparadise.com ping statistics ---
8 packets transmitted, 8 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 239.312/348.039/550.187/108.998 ms
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Tue, Dec 19 2017 8:24 AM
jans:
elephant:
So the ping test is shown above.
What follows is a trace of the route to get to radio.paradise ... then intent is to see which hops take longer than others or indeed time out ... frankly I find this one somewhat confusing ! (I am more used to this test under a Windows environment)
traceroute stream-dc1.radioparadise.com
traceroute to stream-dc1.radioparadise.com (174.36.251.136), 64 hops max, 52 byte packets
 1  192.168.0.1 (192.168.0.1)  5.390 ms  2.958 ms  4.015 ms
 2  10.112.0.1 (10.112.0.1)  12.632 ms  12.371 ms  11.832 ms
 3  * * *
 4  * * *
 5  * * *
 6  198.142.250.205 (198.142.250.205)  25.563 ms
    198.142.250.197 (198.142.250.197)  26.037 ms  26.097 ms
 7  198.142.139.114 (198.142.139.114)  23.497 ms  24.636 ms  23.591 ms
 8  * * *
 9  * * *
10  * * *
11  80.81.69.153 (80.81.69.153)  28.639 ms  27.124 ms  33.614 ms
12  ge-3-1-0.0.pjr02.lax002.flagtel.com (85.95.27.181)  175.501 ms  173.441 ms  174.613 ms
13  xe-1-0-3.0.pjr03.lax002.flagtel.com (62.216.140.117)  173.245 ms  173.088 ms  173.265 ms
14  ge-1-0-0.0.pjr01.lax002.flagtel.com (62.216.140.126)  183.578 ms
    ge-2-0-0.0.pjr01.lax002.flagtel.com (62.216.140.109)  173.441 ms  173.510 ms
15  80.77.2.82 (80.77.2.82)  175.805 ms  172.367 ms  173.277 ms
16  ae6.cbs01.cs01.lax01.networklayer.com (50.97.17.64)  170.568 ms *  172.282 ms
17  * * *
18  69.12.2da9.ip4.static.sl-reverse.com (169.45.18.105)  201.209 ms  198.947 ms  199.421 ms
19  * * *
20  * ae0.cbs01.tl01.atl01.networklayer.com (50.97.17.163)  220.520 ms  420.101 ms
21  ae0.cbs01.eq01.wdc02.networklayer.com (50.97.17.164)  307.427 ms * *
22  ae29.bbr01.eq01.wdc02.networklayer.com (50.97.17.145)  243.226 ms  503.617 ms  307.708 ms
23  ae0.dar01.wdc01.networklayer.com (173.192.18.197)  307.943 ms  305.958 ms  306.353 ms
24  po1.fcr01.sr01.wdc01.networklayer.com (208.43.118.134)  307.396 ms  308.233 ms  305.065 ms
25  * * *
BeoNut since '75
jans
Belgium
Posts 394
jans replied on Tue, Dec 19 2017 7:11 PM
CB:
I removed the station from TuneIn and added it again. It’s now playing flawlessly for a couple of hours today. No clue why it’s now better than the previous days.
I ‘ll keep you posted if things change!
Jan
jans
Belgium
Posts 394
jans replied on Wed, Dec 20 2017 8:00 AM
I also asked the question to BeoCare. This is their feedback:
"We can confirm this strange behaviour with TuneIn on the Essence MK II. In some cases, it will help to select the station again.
Our R&D team is investigating the cause of the problem, but we do not have an expected deadline at this point, unfortunately.
I will make sure to let you know as soon as I receive an update on this and do apologise for the inconvenience caused."
So, it is a known problem. Let's hope it gets resolved soon!
Page 1 of 1 (12 items) | RSS
