Beogram 3000 linear-tracking: tonearm weight query
This post has 13 Replies | 2 Followers
Svatopluk
Posts 7
Svatopluk Posted: Tue, Dec 19 2017 10:51 AM
Dear fellow B and ) enthusiasts,
I have a B and O Beogram 3000 linear-tracking turntable. It has an MMC4 cartridge that was refurbished and given a new stylus by Axel Schürholz about two or three years ago. In short, I've found that I have to set the tracking force a little higher than the top marking of 1.8 for a consistently good sound. Is the Beogram 3000 one of the models where the tracking force can first be set to zero by taking the turnable (partly) apart?
Any advice is appreciated.
Best,
S.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Dec 19 2017 5:18 PM
I have the same table, as for zeroing the arm, the approach to take I think is to get a good stylus force gauge, I use an electronic one, and measure the real stylus force. To do so I need to put a record on, turn on the table and get it to start playing, then I pull power, gently lift the arm, remove the LP and put the force gauge under the stylus. I do this to eliminate any issue with LP thickness but it's probably overkill, I think you can do fine with the LP still on the platter plus it makes it simpler.
I haven't measured the force vs. gauge reading vs. where it's adjusted on the slider in so long I can't remember, but I believe I've always had to set the tracking force a bit higher on the arm slider than you'd think to get it to track well. Say, instead of 1 gm on my MMC2, something like 1.2 gm, so your experience seems to be in line with mine.
Jeff
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Dec 19 2017 6:01 PM
There is a trick... Whistle
Place the stylus gauge under the tonearm.
Press and hold LIFT> for more than 2 seconds and the tonearm will lower onto it.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Dec 19 2017 6:09 PM
Wow Martin! Thanks! Will make it much easier. Cool
Jeff
Svatopluk
Posts 7
Svatopluk replied on Wed, Dec 20 2017 12:05 PM
Thanks for the replies. My follow on question is this: what will I learn from using the stylus force gauge? I gather, then, that it is not possible to 'zero' the tracking force on this model? By going heavier than the recommended force for an MMC4 records like a perfectly clean Decca (blueback) Nutcracker with Answermet have gone from unlistenable to gloriously rich in detail and warm in tone. Or, for another, Joe Jackson's Body and Soul, the high brass are no longer fuzzy and lacking in clarity.
Thanks again!
S.
Dillen
Posts 13,191
Dillen replied on Wed, Dec 20 2017 12:15 PM
You will learn the actual tracking force.
And you can check that the dial is correct.
Set it to f.e. 1.5g and check with the guage. If it shows a weight different from 1.5g, something is wrong.
Set it at zero and the arm should be "floating" freely, and not go up or down by itself, though an absolutely exact zero adjustment is difficult to set
given the dial design.
The need for a slightly higher tracking force is typical for retip'ed cartridges.
For the MMC4 you will typically have to up from 1.3-1.4g to 1.6g-1.7g.
Svatopluk
Posts 7
Svatopluk replied on Wed, Dec 20 2017 12:24 PM
Thank you, that is very helpful. If I do learn a discrepancy in the tracking force, how can it be rectified?
Thanks,
S.
Svatopluk
Posts 7
Svatopluk replied on Wed, Dec 20 2017 12:30 PM
Also, mine doesn't have a dial, but a little plastic slide on the tonearm itself.
S.
Dillen
Posts 13,191
Dillen replied on Wed, Dec 20 2017 3:02 PM
Svatopluk:
S.
- moving on a dial.
Or scale if you prefer.
Svatopluk
Posts 7
Svatopluk replied on Wed, Dec 20 2017 3:26 PM
Thank you—I wasn't trying to be pedantic!
Best wishes,
S.
Svatopluk
Posts 7
Svatopluk replied on Tue, Jan 16 2018 5:24 PM
I notice that some tracking-force gauges ask you to put the needle on the gauge and then adjust the counterweight. How can do that with my B and O where there is no counterweight, only the sliding adjustment? Can you recommend an affordable gauge?
Thank you!
Saint Beogrowler
Saint Paul
Posts 780
There is a counter weight but it’s not the typical radial arm style and probably doesn’t need to be adjusted for accurate VTF.
Musou Digital Turntable Stylus Force Scale Gauge 0.01g Blue LCD Backlight,Tracking Force Pressure Gauge / Scale for Tonearm Phono Cartridge https://www.amazon.com/dp/B071P9VZ5Q/ref=cm_sw_r_cp_api_rxOxAbRDATM33
Svatopluk
Posts 7
Svatopluk replied on Wed, Jan 17 2018 8:24 AM
Thank you! I'll check it out.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Jan 17 2018 5:06 PM
Ultimately it doesn't matter what the sliding scale says, nor what the round counterweight adjustment on a conventional tonearm says, what matters is the actual tracking force as measured with a gauge/scale. I've had a number of conventional tables with conventional arms, and have often found the dial on the counterweight to be off a bit. Especially on arms where the tracking force is set with springs, as the springs age the calibration of dial reading to actual force gets more, well, optimistic.
So, I've always kept a gauge around, at first a beam balance Shure one, now an electronic force gauge that has a digital readout (easier to use, and came with a 1 gm calibration weight). At least with the Beogram you don't have to worry about cartridge alignment that required a protractor to set, or have to mess with arm height to set the vertical tracking angle (VTA).
The main disadvantage of B&O tables is you're locked in to one cartridge type, can't pick out of all the ones out there. The advantages are easier setup, knowing things like VTA and geometry are right without troublesome setup gauges and protractors, and superb isolation to feedback and vibration/footfalls. I started out with a MMC5, dreadful sounding to me. I replaced it with a MMC2, what a spectacular difference, after that when comparing it to my old VPI HW19 and Sumiko setup, I honestly couldn't say one was overwhelmingly superior to the other, even as high end as the VPI was, they just were different, with different strengths and weaknesses.
Jeff
Page 1 of 1 (14 items) | RSS
