How to link a replacement BEO4 to my Beosound 2500?
Peter Dorr
Soest
Posts 22
Peter Dorr Posted: Wed, Dec 20 2017 1:57 PM
I just purchased a used BEO 4 remote for my Beosound 2500 CD/Tape unit.
How do I "pair" them. They are currently resistant to talk/listen to each other :-)
L Spad
Brighton
Posts 271
L Spad replied on Wed, Dec 20 2017 3:33 PM
There is no need to ‘pair’ a Beo4 with your system, it should just work.
1. Are you sure the batteries in the remote are good?
2. Is the system set to option 0 (IR receiver disabled)?
If not there may be a fault on the remote or the IR receiver on the system.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Dec 20 2017 10:01 PM
In order to check that the Beo4 is remote is actually transmitting, view the 'transmit' end through the 'selfie' camera of an iPhone.  You should see the IR transmitters flashing as you press the buttons.
Depending on the model of iPhone, this may not be possible through the main front facing camera.
If the Beo4 is transmitting and the BS2500 still doesn't work, come back to us for advice about A.OPT setting (Luke's second point).
Kromer
Randers, Denmark
Posts 129
Kromer replied on Wed, Dec 20 2017 10:20 PM
And finally there is the (small) possibility that the Beo4 is set to link mode?
Page 1 of 1 (4 items) | RSS
