Hi everyone,
My intension is to boost up my LG TV sound by connecting old Beolab 8000 speakers with Beosound core and TV. Connection between TV and core with optic cable (optic out) from TV - (Optic in) Core. From Core with powerlink cable to speakers. It works but there is a substantial delay in sound flow. Useless for film, news etc
Someone with same experience?
On your LG you can probably find a setting to adjust the delay between sound and picture to have it synchronised in such a setup. I have this on mine.
http://www.lg.com/uk/support/product-help/CT00008334-1399374324861-general-inquiry
Thanks, I have the adjustment option, but the delay is out of range.
I found out by configure the core. Delay can be disabled under config-sound-optical-disable.
It works:)
