BV 7 40 MK2 + Beosystem 3 question
This post has 5 Replies | 0 Followers
liviu_o
Posts 157
liviu_o Posted: Fri, Oct 5 2012 10:02 AM
Hi !
I have a beosystem 3 and I want to buy a BV 7 40 MK2.
First question: it's a good idea? :)
Second question: Since everything (  dvd, BD, setupbox, media player) is going into BS3 and then a dvi-dvi to BV7 my question is how I will output the audio from the built in dvd player of BV7 to beolabs conected to BS3?
If the answer is masterlink then I need a solution because I also have a Beosound 9000 masterlink conected to BS3 so the masterlink input of BS3 is taken :)
Thanks!
Liviu
kimchr
Posts 170
kimchr replied on Fri, Oct 5 2012 11:51 AM
Have you considered buying a BV7-40 MK3 with built in Beosystem 3 and sell your stand alone Beosystem? I think that would be a more clean setup in most cases...
jkhamler
Posts 286
jkhamler replied on Fri, Oct 5 2012 11:54 AM
Agreed, or how about just getting a used 4-50 Plasma screen and leveraging your existing BeoSystem and BeoLabs?
A BeoSystem 3 and separate BV7 does seem like a cumbersome setup to me.
Jonathan
liviu_o
Posts 157
liviu_o replied on Fri, Oct 5 2012 12:08 PM
Thanks for your answers. Trading BS3 is difficult.
4 50 is not a solution since I am looking to downgrade my 50"plasma to 40" (for tv) and get a projector ( for movies).
Still waiting an answer for the audio out from the 740 dvd to BS3.
Thanks!
liviu_o
Posts 157
liviu_o replied on Fri, Oct 5 2012 4:56 PM
If I'll have my BS3 and a bv 7 40 mk2 using the beo4 will send commands to one or the other. Do you think there will be issues with this setup?
liviu_o
Posts 157
liviu_o replied on Sun, Oct 7 2012 4:07 PM
Nobody?
Such a bad idea to have a 7 40 MK2 conect to BS3?
Still asking about the sound from the BV7 dvd. How I will output it to my BS3?
Thanks!
Liviu
Page 1 of 1 (6 items) | RSS
