hi all, I am thinking of dusting down my vinyl and buying a turntable. I have the beosound 9000 6-cd player, and am wondering if a turntable is something that can be plugged into the aux connector, and the sound will come from my b&o speakers, via the 9000 unit. Does that make sense or am I being far too simplistic?
thanks, and HNY!
Yes, that will work, but be sure to get a turntable with an inbuilt RIAA if you intend to connect only a turntable directly to the AUX in DIN socket of the BS9000.
Suggest a Project deck with built in RIAA will be a good choice.
Peter
