Century and Beo 4 have suddenly fallen out...
This post has 4 Replies | 0 Followers
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw Posted: Thu, Jan 4 2018 4:46 PM
So, I was connecting a Chromecast to the mains (before I had connected the Chromecast to the Century) and the Century suddenly powered off... I'm 99% certain I didn't interrupt the mains supply to the Century.
Switched the Century back on, all works fine including the Chromecast connected to AUX, but, it refuses to react to any command from the Beo 4. The Beo 4 is fine - works my 5500 perfectly.
I'm proper stumped!
Any help appreciated
Cheers
Nigel
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Jan 4 2018 4:53 PM
Remove the glass, clean it thoroughly. Hoover the front grilles, including the little black strips between, replace glass.
If that doesn't work, your IR sensor needs replacing.
Lee
Smile
h1npw
Posts 1,130
h1npw replied on Thu, Jan 4 2018 6:32 PM
Hi Lee
Yes, I used that trick (that you taught me) before I started the thread to no avail...Angry
Damn, must be the IR sensor... I feel a trip to Tim coming on...
However, apart from cannibalising an old unit, any ideas, anyone, where I can get one from?
Cheers
Nigel
marexy
Posts 710
marexy replied on Fri, Jan 5 2018 7:45 AM
Hi
few of those i fix it so that i change capacitors on the IR receiver PCB.
try it..
h1npw
Posts 1,130
h1npw replied on Fri, Jan 5 2018 9:44 AM
Thanks Marexy. Beyond my technical capabilities, but I know a man who can!
Cheers
Nigel
Page 1 of 1 (5 items) | RSS
